02-23-2010, 09:56 PM | #1 |
summit headers
Are they any good .. would i be better off buying another brand ?
350/th350 Sportsman2 heads Performer Intake 1406 carb 3.42 Eaton Posi |
02-23-2010, 10:26 PM | #2 |
Grandpa in the rustmobile...
Re: summit headers
free bump id be interested also, usually sumit brand is acually a brand stuffed in a white box marketd 'summit'.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-23-2010, 11:08 PM | #3 |
haha, ford guys...
Re: summit headers
passenger side must be dented to clear frame. they will tell you other wise.. they lie. i used a pipe and a hammer..... eventually the torque of the motor will make room. i doubt it really effects performance.... this was on my 71gmc
02-23-2010, 11:10 PM | #4 |
Re: summit headers
I am running a cheap set of summits on my 72 blazer and installing A set of coated summits on a 72 gmc k-10 customer truck so far so good cant beat the price!
02-24-2010, 12:11 AM | #5 |
Re: summit headers
I bought a set of hedman elite coated headers from a place called street side auto for $260 shipped. They seem to have sales going on all the time and I got free shipping. I haven't installed them yet but they look really good.
02-24-2010, 02:27 AM | #6 |
Re: summit headers
I have summit brand headers on my 67 and my dad bought a set of flowtechs from autozone for his they are the same... identical if you will. So for what its worth no problems out of either set. Mine are 9 years old his are 6 or so. These are the painted variety btw.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80 Nice ride 67 Chevy C-10 LWB Built 350 TH-400 Wifes ride and family rig: 2001 Furd Expedition 5.4 Liter Kickin back in Rolla,Mo. USA "Do the thing you fear most and the death of fear is certain" Mark Twain |
02-24-2010, 03:45 AM | #7 |
Re: summit headers
Running summit brand since '02 on 2wd manual. No clearance problems at all, not even with the stock " z" bar clutch linkage. I did not need to dent mine to clear the frame. They have held up quite well, why spend more money?
02-24-2010, 06:04 AM | #8 |
Re: summit headers
Yep when mine finally rust through I am going with the summitt headers too..
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
02-24-2010, 07:56 AM | #9 |
Re: summit headers
I ran a set of flowtechs on mine. Fit couldn't have been any better. No interference anywhere. Had to modify my AC bracket buy cutting part off because it mounted over exhaust manifold. Also new Alt. brackets because mounted to front of exhaust manifolds. This is on a 68 C20 with 327, no holes in front of heads for bracket mounting. Installed from bottom, didn't have to remove anything, didn't even have to raise truck. It's a c20. Good luck with the install. Go with Copper gaskets though.
02-24-2010, 07:58 AM | #10 |
Re: summit headers
I have a set of Summit headers on my `70 C-20.I had no issues with frame interference or otherwise.I'm running a hyd clutch so can't vouch for manual linkage clearance,but it looks like there should be clearance. I bought the painted ones for $99.00 since I don't drive mine in the salt in winter.
Bob |
02-24-2010, 08:18 AM | #11 |
Re: summit headers
I bought a set of the "summit headers" 5 years ago and have had no problems with them i belive they came with all hadware/gaskets too and if remember they're made by pacesetter/monza there logo is stamped on the headers
02-24-2010, 08:31 AM | #12 |
Watch out for your cornhole !
Re: summit headers
I speak from personal experience. Mine fit fine, I didn't have to modify any tubes.
Before I installed them, I noticed a part number stamped into the tube near the collectors on the bottom. Google search of that part number brought up Dynomax's webpage for GM truck headers. They are Dynomax headers.
02-24-2010, 11:21 AM | #13 |
Re: summit headers
All i can say about hedder purchases is to watch the tightness of the bends where they come out of the heads. I bought a 67 1/2 ton last week. I was running poorly ( choke wasnt opening all the way. Carb needed adj. And vac adv was hooked to manifold vac not ported from the carb ). After this i went to install new plugs and had to get four accell shorty plugs for hedder clearance. These arent cheap. A real shame cause the hedders are ceramic coated, and there was no reason to bend them this tight.
02-24-2010, 11:20 PM | #14 |
Re: summit headers
Here's mine guys the 99$ pair came with hardware and gaskets. And as stated above fit great. Here's some pics.
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011 Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
02-24-2010, 11:39 PM | #15 |
Re: summit headers
To the op, they are the same as flowtechs. On my lwb I didn't have to clearance the flowtechs. Small block.
'72 cheyenne super step, '05 long bed gmc |
04-03-2010, 01:14 PM | #16 |
Re: summit headers
I believe the summit headers have only a 1 1/2" primary.
355,vortec heads, Doug Herbert cam, Performer intake, 750 Holley, Hooker Comps, 2 1/2 duals w/Aero Chambers, 2500 stall and 3.73 posi. |
04-03-2010, 04:57 PM | #17 |
Re: summit headers
THats correct, perfect for boosting torque on stock to mild sbc's. Stock manifolds only have a 2" outlet altogether..
