Old 07-19-2019, 11:42 PM   #1
Drummerboy
Drummerboy's Avatar
Seat back will not told forward???
I just picked up a very nice 1969 GMC Custom. The seat back will not fold forward. Do they not fold forward? My 68 Chevrolet did.
Drummerboy is offline   Reply With Quote
Old 07-19-2019, 11:46 PM   #2
fb111ewo
fb111ewo's Avatar
Re: Seat back will not told forward???
I believe that 67-68 were the only ones that folded, starting in 1969, they did not fold anymore.
fb111ewo is offline   Reply With Quote
Old 07-19-2019, 11:47 PM   #3
Grumpy old man
Grumpy old man's Avatar
67-early 68 fold safety regs in 68 required the seat to be bolted so 68-72 don't fold .
Old 07-20-2019, 08:00 PM   #4
franken
It looks like the design still allowed for the fold. I bet it wouldn't take much to make the later seats fold.
Old 07-21-2019, 12:34 AM   #5
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Learned something today. IMO you don't gain much with them folding forward, the seats push forward pretty nicely. That said, if my 72 folded forward then I could read the build sheet
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-21-2019, 07:18 AM   #6
Grumpy old man
Well ... if you build a custom flip seat with pockets you can carry the important things .
Old 07-21-2019, 11:17 AM   #7
Wrenchbender Ret
Can anyone tell me how to fix it so I can fold it forward to get to the gas gauge sending unit on my 72?
George
Wrenchbender Ret is offline   Reply With Quote
Old 07-21-2019, 11:33 AM   #8
Grumpy old man
push the seat all the way forward and lean over , You can't make the Non folding seat lean forward without loosening the material at the back bottom corner and then removing the #3 phillips screws from the legs that hold it to the bottom frame and you take the risk of tearing up the seat material . if you can't get the access you want by moving the seat forward remove the seat to floor bolts and lift the entire seat out .
Old 07-21-2019, 12:35 PM   #9
Grumpy old man
Here are a couple pictures of the folding seat back from a 67 truck , Notice the the upper frame is wider than the seat frame to allow the top to fold without damaging the material ,Also the single pivot shoulder bolt , Along with the "latch" mechanism using a wing nut to secure the seat from folding forward . You can also use the "latch" bolt to adjust seat back lean for comfort .
Old 07-21-2019, 06:15 PM   #10
68Gold/white
My 68 seat is like that...FWIW
68Gold/white is offline   Reply With Quote
