08-22-2012, 03:56 PM | #1 |
Lowering
I am new a member, I have a 1970 C10 LWB 350 vortec roller motor, th350, converted the front to disc brakes, i am planning on doing a build thread, anyways...
I am wanting to lower my 70 but not spend a lot, are those coil spring clamps ok to use? i want to see if i like the look and ride before i buy the springs. I was thinking bout doing either 2" front and 2" back or just 2" front to get a racked look, will i have to do any body or frame mods to do this? thanks guys! |
08-22-2012, 07:19 PM | #2 |
Re: Lowering
Not sure about clamps but 2" drop springs are pretty cheap and easy to install. If it has the factory springs in it you might already have a 2" drop on it There are lots of threads and pics of drops on here....you should have no problem finding the right look for yours. Use the search option and find what look your after before you purchase anything...also make sure the person whose has that drop and product are happy with it. Good luck
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
08-22-2012, 10:00 PM | #3 |
Re: Lowering
I found on here that if you cut one complete round off your front coil it will lower exactly 2 inches. Half round cut off coil is 1 inch. Here is mine with one round cut off coil= 2 inch drop in the front. I bought 4 Inch lowered springs for the back with 1 inch lower block.
08-23-2012, 08:39 AM | #4 |
Re: Lowering
thanks very much guys, how big of tires and rims are you running on ur GMC?
70 C10 working on a LSx swap 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
08-23-2012, 09:08 AM | #5 |
Re: Lowering
clamping the springs wont give you the same ride as a new pair of springs. i have also seen people cut the springs and that seems to work pretty good but i would cut 1/4 turn at a time until you get the drop you want because there are many different springs and they will all drop a little different it will take a little longer to do but you cant put it back ones you cut it off.
08-23-2012, 09:10 AM | #6 | |
Re: Lowering
08-23-2012, 09:14 AM | #7 |
Re: Lowering
it will change a little. the best way to lower the truck and not change ride to much is drop spindles cause they dont affect spring rate or how easy it is to hit bump stops.
08-23-2012, 01:08 PM | #8 |
Re: Lowering
Im running 20X8.5 up front with 245/45/20 tires and 20X10 on rear with 295/40/20. The ride is pretty good. I put all new KYG nitrogen shocks all the way around. The rear end has bottomed out if I put 400-500 pounds in the bed. Just make sure to keep your rubber stops in place! On regular stance the frame is about 3" from the frame.
Here is a pic to show the space between frame and rear end. Notice the bumper stop was still out. |
08-23-2012, 01:12 PM | #9 |
Re: Lowering
Stance photos from Early Classic Enterprises, they are very helpful, great products, competitive pricing and outstanding customer support.
http://www.earlyclassic.com/tech.asp...nce%20Photos-2
66 GMC Suburban Custom 66 Chevy K10 Suburban |
08-23-2012, 03:05 PM | #10 |
Re: Lowering
thanks for the link that was helpful, jarwood what sway bar are you running? and does it help?
08-23-2012, 04:15 PM | #11 |
Re: Lowering
Got front and rear sway bar from CPP. Also the bent panhard bar from them. They make a great product but are sometimes slow about getting it to you. I can send more pics if you like. I'm by no means a profession, just a hobby that cant stop. I used to work at a body shop 20 years ago....but just love old cars and trucks.
08-23-2012, 04:17 PM | #12 |
Re: Lowering
Oh yeah, they make a huge difference. I can corner about as good as a sports car. All most no roll or dip in the front end.
08-24-2012, 11:54 AM | #13 |
Re: Lowering
awesome thats what i want lol
08-24-2012, 05:14 PM | #14 |
Re: Lowering
71 c10 i used 3 inch belltech drop spindles and 2 inch cpp coils ,in rear 5inch coils only thing running 15inch wheels alot of grinding and it hits going down my driveway but on road its fun and drives and handle good
