"Where were you in '62?"
![]() Join Date: Jul 2004
Check this out fellas.... for those trucks haulin more than hay! Teehee....
NANO Nitrous Nitrogen Assisted Nitrous Oxide http://www.nanonitrous.com/ NANO Nitrous Located in Kansas, NANO (Nitrogen Assisted Nitrous Oxide) has developed advancements to optimize the use of nitrous oxide systems. NANO applies mass flow technology to continually "compensate for changes in bottle temperature and pressure" so the result is constant maximum horsepower gains for the duration of a race. NANO tanks are filled with high pressure air or nitrogen to 4500 psi. Complete regulator kits and accessories are available. NANO: "Turbo performance at nitrous prices." NANO eliminates the performance variations in your nitrous oxide system caused by constantly changing bottle pressures and temperatures. Bottle pressure is no longer an issue. Simply connect the NANO system, it instantly compensates for these variations so you get the full power potential of nitrous oxide power every time you hit the button and it utilizes the entire contents of the nitrous bottle. NANO doubles the runtime from a single nitrous bottle refill, traditional nitrous systems can only utilize about half the nitrous in the bottle. NANO's technology can utilize the full contents of a nitrous bottle without any loss in power. Quicker ET's with NANO, no more deterioration of power as your nitrous bottle empties. You get the same power response every time whether you're nitrous bottle is full or almost empty. Nano Nitrous LLC • 811 E. 28th St., Lawrence, KS 66046 • Phone: (785) 331-2390 • Fax: (866) 422-5550 http://www.nanonitrous.com/
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
Dino burner
Re: NANO Nitrous Nitrogen Assisted Nitrous Oxide, Nitrous on Steroids!
Nitrogen 'push' assistance for nitrous oxide injection systems have been used for a few decades now.
For anyone interested in no-holds-barred systems, check out some of the ProMod, Top Sportsman or Quick 8 focused discussion boards on the web. Lots of discussion about the pros and cons of different system configurations there. |
