Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Old 06-23-2014, 02:56 PM   #1
Oldswrench
upper control arms 67-72
Are there any differences in the upper control arms between the drum brake truck and the disc brake trucks? I know the control arm shafts are all the same, but didn't know about the arms.
Mark
Oldswrench is offline   Reply With Quote
Old 06-23-2014, 03:47 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: upper control arms 67-72
All 67-72 UPPER's are interchangeable.
Keith
Convert to disc brakes.
Old 06-23-2014, 04:36 PM   #3
Oldswrench
Thanks Keith I though that was correct, but I have stepped off into the deep end before on just such a thought!! My 72 needs upper control arm bushings on one side so I thought that I would pull them off of my 69 to just rebuild them with ball joints and everything all at the same time then through them at it and be done with minimal down time. So Thanks again.
Mark
Old 06-23-2014, 06:29 PM   #4
lolife99
lolife99's Avatar
Let me be clear,... the upper a-arm is the same,... the balljoints will be different.
So get the balljpoint that matches the spindle you are using.
Keith
Old 06-23-2014, 08:01 PM   #5
Oldswrench
Got it thats what I have 72 upper ball joints and control arm shaft kits for the disc brake spindle, just wanted to use the 69 A-Arms so that I could install the new parts and be ready when I tear down the 72 to replace all of the this. Then if I ever get back to the 69 I can use those A-Arms there with the appropriate parts. Thanks again.
Mark
Old 06-23-2014, 08:14 PM   #6
lolife99
lolife99's Avatar
Good plan^^^
Keith
Old 07-02-2016, 03:45 PM   #7
snipescastle2
snipescastle2's Avatar
Talking Re: upper control arms 67-72
Just wanted to add to this so somebody else doesn't go through what I did (put the upper control arms on the wrong sides) just so you know, the rubber
"Snubber" (bumper goes towards the rear of the control arm, not the front, if you do this, there is no way to adjust the caster. the lower control arms are a
"No Brainer" as the lower shock bracket is on the rear side of the control arm and it would be obvious that it wouldn't work.
Have a good one!!!
Ben
here is a few pictures showing the correct assembly, thanks DavePL and Everettelane
the last one shows how my wheel wasn't centered in the fender
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
