05-02-2005, 07:36 PM | #1 |
Vent Windows
Can the rubber molding in the vent (wing) windows be replaced without tearing the vent window frame apart?
05-02-2005, 07:43 PM | #2 |
Saving 1 truck at a time!
Not to my understanding. There are about 6-8 special rivets that hold the rubber in place and one or more are a real bear to get into place. I guess you need a special tool. PICKMUP has one for sale. These are special rivets too...not a pop rivet.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
05-02-2005, 07:46 PM | #3 |
no you have to seperate the frame to get the new rubber on or it will never seal believe me i looked and tried and it wont happen
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
05-03-2005, 12:41 AM | #4 |
I've just done this recently so i'll try -
1.Buy a tool and rivet set. Get some extra rivets in case you mess up. 2.Grind a flat spot on tool end like in pic. This will help installing one of the top rivets later. 3. Have a helper to hold things. 4. Remove old window liner fabric on long channel. 5. Soak nut on shaft with PB Blaster day before. 6. Put window in center of travel so as not holding against either stop. 7. Bent down tabs under nut. Note amount of threads above nut for reassembly. 8. Carefully remove nut, hold shaft with vise grip if nut seems tight. 9. Shaft WILL twist off on window if nut is stuck (yes I broke one). 10. Remove nut, spring etc. Note position of cam stop and washers etc for reassembly. 11. Use sharp 1/4 drill bit, apply light pressure and remove pivot rivet. 12. Remove window from frame. 13. Drill out top two rivets. I did not remove lower rivets. 13. Twist frame slightly to side and drill out 4 rivets on flat seal. 14. Remove flat seal and then remove the "V" shaped seal. 15. Put a plastic tie wrap through top rivet holes to hold it together while you clean it up. 16. Use some silicone spray lube and install the "V" seal. 17. Check holes in flat seal with rivets and enlarge if necessary. 18. Place lower end of flat seal inside of lower part of "V" seal. 19. Push rivets through from back side through the seal. 20. Place channel with rivet head over square punch or similar tool mounted in vise. 21. Using riveting tool, flatten all 4 rivots in flat seal. 22. Slightly bend top end of flat seal up so top end of "V" seal can slide under it. 23. Hook top end of "V" seal under flat seal, and install top rivet and flatten partially. 24. Install second rivet from top, this is where the flat grind on tool helps, and flatten, and finish riveting top rivet. 25. Reinstall window, with cam and washers in proper postion. 26. Rivet in new pivot rivet 27. Install washer and spring and nut, adjust for proper tension. 28. Bend up locking tabs and you are done. Hope that helps - Tom
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 05-03-2005 at 01:00 AM. |
05-06-2006, 12:39 PM | #5 |
Oilfield Trash
Re: Vent Windows
Just another trick to add to Green machines post, because the pivot rivet is such a pain to reinstall, just leave it alone and only remove the bracket off of the window frame. Then when you have everything esle done(new rubbers in, frame riveted back to window channel, etc.) pull back the frame rubber a little bit, and use pop rivets from the INSIDE of the frame to reatach the vint window and bracket, clear as mud, right!
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
