09-21-2015, 11:39 PM | #1 |
Iso 5-7 blade mechanical fan blade
I need a 5 to 7 blade fan for my 250 i-6 that is mechanical. Anybody know where to get one of these critters. I,ve looked everywhere around here at home.
Thanks bob in tn.
I BELIEVE IN JOHN 3:16 |
09-22-2015, 12:02 AM | #2 |
Too many projects
Re: Iso 5-7 blade mechanical fan blade
I've ran a 6 blade fan off an 80s small block (I think, it was a loose fan after my stock one shot off a blade 600 miles from home)
I've switched to electric fans on my 63 Nova, if you can't find one locally you can have mine for the cost of shipping.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
09-22-2015, 12:12 AM | #3 |
Is it a mechanical fan or does it have a clutch ? I dont care for the clutch type. Thanks
09-22-2015, 12:46 AM | #4 |
Too many projects
Mechanical, I only had 1" of space between the radiator and water pump. Reduced to 5/8" with aluminum radiator plus it would have hit my new A/C compressor so I had to switch to electrics. Under the hood is really tight in the little Nova with a hopped up 250.
Kept the six cool for the couple years I ran it.
09-22-2015, 12:46 AM | #5 |
20' Daredevil (Ret)
No clue what turned you against them, but clutch fans are the only thing I'll consider using, unless it's a vehicle with electric fans already on it. Not that there's anything wrong with a good electric fan conversion.... just that I would never use a fixed-blade fan (and certainly not a flex fan).
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-22-2015, 07:35 AM | #6 |
A 6-blade rigid fan is a HP robber. Look at this dyno test from Car Craft.
http://www.network54.com/Forum/21565...+Fan+Dyno+Test A clutch fan was closest to electric fan or no fan at all.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
