07-31-2015, 02:05 PM | #1 |
Steering wheel
i had a grant after market steering wheel on my c10 truck, i am about to replace with old period wheel. when i took the after market wheel off this cog thing was underneath,do i need to keep this on ? if so the new wheel will not fit any help please |
07-31-2015, 02:10 PM | #2 |
Never Ending Projects
Re: Steering wheel
I think that was some part for the Grant adapter but I have never seen one like it. It is definitely not original to the steering column.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-31-2015, 02:20 PM | #3 |
Re: Steering wheel
can you just put the steering wheel on the splines and do up the nut
07-31-2015, 02:59 PM | #4 |
Re: Steering wheel
if it is the stock type wheel that is the way that it works
ron |
07-31-2015, 03:06 PM | #5 |
Moderator
Re: Steering wheel
That's a column lock used in 70's GM columns, they probably used it for a spacer on yours if it is a mid 60 column.
07-31-2015, 03:09 PM | #6 |
Re: Steering wheel
just been doing a bit more reserch and its a locking plate,what i need to know is do you have to put it back on ?
07-31-2015, 03:12 PM | #7 |
Moderator
Re: Steering wheel
Ohhhh it's a locking plate. That's interesting.
Do you have a 70's steering column or a mid 60's unit? No telling since it's not in your sig. Cause my 64 doesn't use it.
07-31-2015, 03:24 PM | #8 |
Re: Steering wheel
07-31-2015, 04:28 PM | #9 |
Re: Steering wheel
Ah, that's a big piece of the puzzle to leave out. I was thinking it was a stock C10 column. No idea on if you can leave it out, as I haven't worked with a Camaro column in years.
07-31-2015, 05:51 PM | #10 |
Re: Steering wheel
It helps keep the turn-signal cancel cam piece tight against the column's upper bearing. I would imagine it would be better to keep it on and if it didn't have it, find the lock clip[ to keep it tight in place.
07-31-2015, 05:52 PM | #11 |
Moderator
Re: Steering wheel
There should be a spring underneath it. I don't know if there will be enough tension to keep the whole assembly from being loose once the retaining spring/ring clip is put back on (above the ring you are showing). Does that make sense? Not sure if I'm explaining it properly. You could try it.
