Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Product Reviews
Old 12-02-2002, 02:45 AM   #1
jay-dawg
chevelito
jay-dawg's Avatar
Question craftsman easy out???
Anybody have any experience with this tool? I have two screws that I stripped the heads off of. The first is for a metal door panel screw. The second one is for the arm rest.
just wondering if this tool is a good investment or is there another home remedy?
I tried using pliers but I cant grip the screw edges.
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 12-02-2002, 03:02 AM   #2
Capitol68
Capitol68's Avatar
u might try a left handed drill bit, alot of times it will back right on out
'68 Fleet LWB
orig 307 .030 over
GM Hei/w Accel Super coil
orig. stock TH 400.
_______________________
“What we do for ourselves dies with us. What we do for others and the world remains and is immortal.”
Albert Pine
English author d.1851
Capitol68 is offline   Reply With Quote
Old 12-03-2002, 08:02 PM   #3
DR67
DR67's Avatar
Just purchased a set recently, I have found that some screws are so soft that these do not work very well, they just strip the heads even more.
DR67
Dave
Knoxville,Tn.
DR67 is offline   Reply With Quote
Old 12-04-2002, 05:16 AM   #4
chevyhouse
BEER-Vacation in a can...
chevyhouse's Avatar
make sure you are using the right size drill bit for the ez out and you can get almost anything out with them. drill your hole, insert ez out and give it a LIGHT tap with a hammer (stress the LIGHT) and turn slowly, should come right out. also it is very important to drill the hole and insert the ez out straight.
Kurt
03' Trailblazer
69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik
2000 Yamaha V-Star 1100 Custom
For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics
chevyhouse is offline   Reply With Quote
Old 12-04-2002, 10:39 PM   #5
DR67
DR67's Avatar
The tool I tried is called a screw extractor, it is not the same as , nor does it work as well as an easy-out. I bought it for removing some screws that would be pretty small to drill for an easy-out. Did not work very well.
DR67
Dave
Knoxville,Tn.
Old 12-06-2002, 03:15 PM   #6
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
i've got a set of those craftsman screw deals. they work pretty well on decent sized screws and u just gotta be sure you put good pressure on em and go slow so the bit bites good. no experience with small screws tho
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 12-10-2002, 01:54 AM   #7
neonlarry
neonlarry's Avatar
I tried the screw extractor things, and I didn't like them. They ended up just making a worse mess than I was trying to fix with them. I guess they might work for some stuff though.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-11-2002, 09:42 PM   #8
BIGG BELLY
you could always try drilling the head off the screw to get the panel off. then grab whats remaining with a pair of visegrips to remove it---just my 2cents
55 big window long bed
69 olds 98
check out my pics
photo albums
BIGG BELLY is offline   Reply With Quote
Old 12-11-2002, 10:43 PM   #9
jay-dawg
chevelito
jay-dawg's Avatar
actually, that's a good idea.
jay
Old 12-12-2002, 10:57 PM   #10
MikeB
MikeB's Avatar
I swear by the screw extractors that use 4 straight "flutes" that run the length of the extractor. They grip well but don't put outward pressure on the broken bolt like the traditional easy-outs do.
It's the second tool shown on this page:
http://www.mytoolstore.com/hanson/extractr.html
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is online now   Reply With Quote
Old 12-20-2002, 01:58 PM   #11
jay-dawg
chevelito
jay-dawg's Avatar
well, to make a long story short, I opted to use a cut off whell and ground the head off.
jay
Old 01-19-2003, 03:30 AM   #12
bill_ont_canada
Nobody is perfect...
bill_ont_canada's Avatar
We have an old screwdriver we set it on the head of the screw and tack it with the mig.
Works every time as long as there's no plastic close by.
When you're done just break the screw off the screwdriver and clean the tack weld off with the grinder,ready for next time.
Have a fabulous day.
Bill... (ö¿ö)
" Loud Pipes Save Lives "
bill_ont_canada is offline   Reply With Quote
Old 02-14-2003, 07:28 PM   #13
jeffbo
D.U.F. Member
jeffbo's Avatar
I bought a set of those Craftsman screw extractors and I wasn't impressed at all. They didn't work very well. I managed to get out 1 of 5 screws with them, and after only those 5 uses, one of the bits was already chipped and marred on the end. I expected a lot more from Craftsman. What a joke.
MEMBER OF THE DISCS UP FRONT CLUB
'72 C-10 LWB Highlander, A/C, tilt TH350 w/ B&M shift kit, 327LJ bored .040", cast flattops, forged crank, L31 Vortecs, 9.25:1 CR, Comp conical valvesprings, Crane Energizer single pattern 216/.454", Professional Products Power Plus Crosswind intake, Edelbrock #1406 600cfm, HEI, dual exhaust, open 3.08 12bolt
'68 C-10 4spd (not running)
'79 C-10 LWB Mild 350
'80 Caprice Classic, 2-dr
'97 GMC K-1500, SWB, Reg. Cab, Z-71, 5.7, Auto
jeffbo is offline   Reply With Quote
