Old 07-06-2018, 08:43 AM   #1
Grumpy old man
Grumpy old man's Avatar
Removing cab drip rail caulk
Everybody hates all the time and tedious work it is to really clean out the old drip rail caulk before shooting epoxy primer and resealing prior to paint . Put down the screw drivers , hammers and picks and grab an air powered windshield tool (used for cutting out old windshields) They vibrate at high speed and really cut right thru the old caulk and sealer that has been applied over the years , It cleans it right down to bare metal removing all of it and doesn't leave any damage to the metal , You can pick up an electric version from harbor freight for less than $40.00 and other than cleaning drip rails and cutting out windshield gaskets it works great removing old glue in door seals , undercoating and such prior to your repaint project . it will save you tons of time and aggravation
https://www.harborfreight.com/variab...ool-63111.html
Old 07-06-2018, 09:10 AM   #2
mkmc69
mkmc69's Avatar
Re: Removing cab drip rail caulk
Great idea. Thanks for the tip.
mkmc69 is offline   Reply With Quote
Old 07-06-2018, 11:55 AM   #3
jeffahart
jeffahart's Avatar
Yes, nice tip... I'm about to peel drip caulk. Is that tip blunt all the way around like a screw driver or is it sharp on the edges? I tried a search for a similar attachment for my oscillating tools. I may just modify one of my wore out tips. Should I sharpen edges or leave blunt?
Thanks,
j
White K20
jeffahart is offline   Reply With Quote
Old 07-06-2018, 12:04 PM   #4
jeffahart
jeffahart's Avatar
I found a couple attachments at auto body tool mart. Think I will get them, unless I can find a bit cheaper.
https://www.autobodytoolmart.com/equ...iABEgIw6PD_BwE
https://www.autobodytoolmart.com/equ...e-p-33519.aspx
Thanks again!
I like the easy button!
j
White K20
Old 07-06-2018, 12:23 PM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Another good tip. You can't be too grumpy if you're sharing such good ideas. ........LOL
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-06-2018, 01:10 PM   #6
morepwr
Good idea! Especially since this is a job I am getting ready to do.
morepwr is offline   Reply With Quote
Old 07-06-2018, 10:28 PM   #7
lutronjim
I too would be interested in blade specs. I have a Fien and I'm pretty sure it would cut right on through the cab.
lutronjim is offline   Reply With Quote
