Old 02-05-2005, 02:53 PM   #1
smitty62
smitty62's Avatar
? about adding TPI?
I'm getting together the stuff I need to add TPI to my '68 and have a few ? Did (or should) you use a short water pump? long? --or serpentine? Stock fan and shroud or electric?
Please keep in mind my heads are 186's with accessory holes. Pics of your setup would surely be appreciated to: ras36@yadtel.net Thanks!
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 02-06-2005, 01:00 AM   #2
smitty62
smitty62's Avatar
Bumpety
Smitty
Old 02-06-2005, 01:18 AM   #3
Russell
Professional Grade
Russell's Avatar
You can use whatever you want
If you do want to run the V-belt setup, make sure that the alternator bracket isn't gonna cause issues. I dunno if your truck has that driver's side alternator bracket, or if it has one of the newer passenger's side brackets that goes up overtop of the alternator, but with the newer pass side, the top of the alt bracket will hit the throttle body. With serp, you may have to clearance the tensioner pulley a bit, but it does depend on the different setups
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-06-2005, 09:48 AM   #4
smitty62
smitty62's Avatar
Sounds good! Are you running an electric or stock fan? If it will work, I'll be using the stock '68 alt. bracket. Also was thinking I would use a '94/'96 Impala SS plastic duct elbow to get intake away from radiator heat--do you think that would work? Do you have any pics of your setup? Thanks!
Smitty
Old 02-06-2005, 11:59 AM   #5
71swb4x4
71swb4x4's Avatar
Here is how I routed mine to get it out of the way of the fan. I used all of my stock front end (alternator, water pump, fan, etc.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-06-2005, 12:45 PM   #6
smitty62
smitty62's Avatar
Yeah! That'll work! What elbow did you use ? I'll have to route to clear an A/C compressor too. What air filter do you plan on using? I know there are more '67/'72 TPI installations out there--so how 'bout some pics? Thanks Guys
Smitty
Old 02-06-2005, 01:41 PM   #7
71swb4x4
71swb4x4's Avatar
I got my elbow from www.jagsthatrun.com same place I got my vehicle speed sensor from. The elbow is a 4" x 3" 90 degree. The 4" side goes on the throttle body. I cut about an inch off it to pull it away from my fan a little more. I have a cone filter coming off the mass air sensor.
Old 02-06-2005, 05:04 PM   #8
Russell
Professional Grade
Russell's Avatar
I am using electric fans myself, and I plan to rig up the Trans Am Air induction setup to work in my truck
Old 02-06-2005, 09:34 PM   #9
smitty62
smitty62's Avatar
OK, do you guys see any reason this (see pic) couldn't be adapted to the TPI mouth? (I won't be using a MAF sensor). Maybe use the original MAF boot? (I've got one of those). It's intended for use on a 'Vette.
Smitty
Old 02-06-2005, 09:36 PM   #10
71swb4x4
71swb4x4's Avatar
If you are going to run electric fans it shouldn't be a problem. Not sure if you have enough room with an engine driven fan. Try to get some measurements from the seller just to be sure.
Old 02-07-2005, 02:35 PM   #11
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I went with a pair of 14" electric fans when I did my conversion.The K+N filter I use interferred with the stock clutch fan setup.
Although I believe with the rubber 90 in 71swb4x4 pic you'd be able to run the factory fan.
Here's my set-up.
I made the metal shroud the fans are in.
Here it is installed.
The TPI
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-07-2005, 03:39 PM   #12
smitty62
smitty62's Avatar
Bobbyk--that sure looks nice. What did you use for a water inlet under the plenum? I understand it's difficult getting a hose under the TPI and I don't want to use one of those $55 aluminum outlets!! I would also really like to get the air intake away from the radiator without spending a fortune. Great job! Anyone else got some TPI installation pics? I'm looking for all the ideas I can find!
Smitty
Old 02-07-2005, 03:42 PM   #13
smitty62
smitty62's Avatar
Also Bobby--do you think a stock fan might work using a 1 1/2" or 2" fan extension?--or would that have put it into the radiator? (No engine in mine so I have nothing to look at).
Smitty
Old 02-07-2005, 09:20 PM   #14
gmc67swb
gmc67swb's Avatar
For the guys who have done this, did any of you have linkage style throttle and have to convert to cable? What I'm askin' is what did you do for throttle operation on the throttle body?
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 02-07-2005, 09:33 PM   #15
smitty62
smitty62's Avatar
Throttle rods won't work---------must use cable. You can see the cable in Bobbyk's pictures.
Smitty
Old 02-07-2005, 10:25 PM   #16
71swb4x4
71swb4x4's Avatar
I already had cable, but I did have to get a longer cable. I grabbed a long cable from teh pick-n-pull and shortened it for my application. It was easy since I had a cable to start with.
Old 02-07-2005, 10:49 PM   #17
rustyold72
rustyold72's Avatar
To get the air intake away from the radiator you can use PVC pipe and Fernco couplings, I know it sounds ghetto, but use the black colored PVC, and the Fernco is black as well so it looks better than it sounds, use a 3rd gen T/A air box mount it down by the radiator support (cut a hole in the rad support if you want) alot of the 3rd gen f body guys have used this methot with some success, if thirdgen.org is back up take a look over there for intake setups
71 Chevy C10 "The Rust Bucket"
72 Chevy C10 apart in the garage
02 WS6 T/A Fast Black and bad@$$
93 Nissan Pathfinder "Emily" Totaled RIP girl
05 Jeep Grand Cherokee-HEMI powered
87 Iroc Z28 305 TPI auto (crying out for an LS1 swap)
rustyold72 is offline   Reply With Quote
Old 02-08-2005, 04:39 AM   #18
BobbyK
BobbyK's Avatar
Smitty,I tried a fan spacer before I went with the electric fans.I ended up with a wicked vibration at about 2500rpm.
I replaced the orig. aluminium TPI thermostat housing with a cast one.
The application is for a a 64-78 Chevy truck with a 327ci engine.
Here's the car Quest part number.
This T-stat housing let's you use the orig. upper rad hose and orientates the outlet facing the rad(more or less).The orig. t-stat housing interferes with the throttle linkage on the TPI throttle body.
Here they are side by side
Old 02-08-2005, 10:38 AM   #19
smitty62
smitty62's Avatar
Many thanks to you guys! This is the kind of info I was looking for and the pics are a big help. Right now, I'm trying to decide if I want to powder coat the TPI unit or bead blast it and leave it natural (which won't last long). Thanks again!
Smitty
