Old 04-18-2014, 11:47 AM   #1
dmcclanahan
piston question
I have a 350 that has a spark plug that keeps gumming up. Am I right in thinking its the piston ring? If so, do I re-ring just the one or all eight? If its not the piston ring what is it?
dmcclanahan is offline   Reply With Quote
Old 04-18-2014, 12:39 PM   #2
geezer#99
geezer#99's Avatar
Re: piston question
It's likely a valve seal.
Clean the plug real good or use a new one, run it awhile (go for a cruise), pull the plug and look for oil on the plug threads.
The only place that oil will come from is a valve seal that's caput.
Old 04-18-2014, 12:48 PM   #3
dmcclanahan
Re: piston question
I didnt even think about the valve's. Ill try you test out. Thanks...
Old 04-18-2014, 07:31 PM   #4
Corts60
Just here to tinker
Corts60's Avatar
Re: piston question
First thing you should do is a compression test. This will tell you the condition of your rings and/or valves. If you test it and have low compression numbers, add a teaspoon of oil to the cylinder with low compression and test again. If the compression rises after that, you have worn rings.
One thing you can do (as a band aid) if you do not want to repair anything right now is run a hotter plug. That will help burn the oil off of the insulator and keep it from gumming up.
