Help Identifying Parts Found In 305e Oil Pan
I have been doing some maintenance on my '66 and found two pieces in my oil pan after I took it off. One appears to be a clip of some nature and the other piece is a partial chunk of something that is made of either hard rubber or plastic. Any idea what either of these things might be? Any help would be greatly appreciated!
http://imgur.com/a/Lb5s1 http://imgur.com/a/78KjS
'66 GMC K25 (305 V6, SM420) aka "Mabel" Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082 All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado |
![]() Join Date: Jan 2011
Re: Help Identifying Parts Found In 305e Oil Pan
Not sure on the rubber part. The wire piece looks like an inner valve spring.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
That's what I initially thought but it doesn't appear to be a piece of a broken spring. Both ends just have a "sharp" point that appears to be manufactured. Almost looks like some sort of retaining clip. I thought it might be a wristpin circlip, but o can't find any that resemble it online.
![]() Join Date: Mar 2013
I'd be pulling both valve covers and inspecting all the valve springs, the rubber looks to be from an umbrella seal. Any engine noise?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Nothing that stands out. I'll be underneath it today working so I will inspect the bottom-up and then pop off the valve covers to inspect.
I'd be willing to bet that is a broken wrist pin clip. Was your engine ever rebuilt? If so they may have used the wrong clips. I had the same thing happen to my 305. Found the broken clips in the pan. Unfortunately for me, when the clip broke, the pin moved back and forth and gouged the cylinder. I had to have a sleeve installed.
#7 | |
I don't believe the engine has ever been rebuilt. I guess inneed to figure out exactly what a factory wrist pin looks like. This definitely doesn't look like a portion of a part. It looks like a complete piece with the ends formed like those of a hog ring. http://imgur.com/IKteMJw
#8 | |
I believe I locating source of "plastic/rubber" piece but I am unsure of what the object is. Appears to be a plug of some sorts on front/bottom of block that covered by oil pan.
http://imgur.com/a/5cfnf
![]() Join Date: Mar 2015
Part of the oil pump pressure relief spring?
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
I'll have to look into that tomorrow. It's worth a shot. Thanks!
