11-16-2020, 05:59 PM | #1 |
How to place a distributor in a new L31 Vortec?
Ive been looking at 350 small block videos on how to install a new distributor but I dont have the timing plates that I see in the videos with a tab and numeric markings. Whats the best way to get things lined up right?
I have the new melonized gear on the distributor and before I place it in I would think that I need to take the driver side valve cover off and rotate the harmonic balancer until the 2nd lifter on the 1st cylinder has dropped back down, which should show the slot on the balancer and the divot on that tab thing line up? This is the distributor, before I installed the gear. And some pics of the timing tab and mark on the balancer |
11-16-2020, 07:29 PM | #2 |
Re: How to place a distributor in a new L31 Vortec?
I rolled mine by hand and felt for puff out plug hole and lined up the t-cover notch to balancer notch . Dropped in in as normal with breakin lube on gear and no problems for over a year or daily driving. I set the timing on my edelbrock pro-flo 4 aspr direction with digital timing light that compensated for not extra timing marks .
Dont forget to get the plug for the crank sensor hole on the bottom of the timing cover or you will get a MASSIVE oil leak .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-16-2020, 08:18 PM | #3 | |||
I had primed the engine with a drill and the prime tool with break in oil in there. I didnt look at the the front afterwards but as I was looking for the sensor hole you mentioned I saw some puddles on the block. I need to find out where they would have oozed out from. |
11-16-2020, 08:46 PM | #4 |
my new gm engine had oil all over it from being built . no leaks so far i didnt do my self .
11-16-2020, 08:51 PM | #5 |
this was the one i got . but there out of stock for now . https://www.eficonnection.com/home/p...illet-aluminum
there are other brands . and some just put the sensor in and call it good . but a new sensor cost a bit more and you still need the bolt .
11-16-2020, 10:28 PM | #6 |
60-66 Nut
The videos you have watched about installing the distributor in an L31 are specifically for when you have the factory EFI. For what you are doing the procedure is exactly the same as for any small block with a carburetor.
11-16-2020, 10:32 PM | #7 |
Get some timing tape. You put it on the balancer and it allows you to use your standard timing light and the notch to get the timing right.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-17-2020, 11:12 AM | #8 | ||||
or an expansion plug https://www.napaonline.com/en/p/SEP3819013 I saw that on this thread that the Captain himself was contributed to 10yrs ago. http://67-72chevytrucks.com/vboard/s...d.php?t=396643 If the expansion plug cap is easy enough to install at this point I could give that a go? Quote:
https://www.youtube.com/watch?v=O4WRL513Gx4 Quote:
On this L31 swap from my old 350, are there any other gotchas that I should know about ? The sensor plug I would have never known to look for, I am just a green as can be with this stuff. |
11-17-2020, 12:35 PM | #9 |
Do you have a temp sensor installed? If not, member A1971Blazer turns them down on a CNC and they come out really nice.
11-17-2020, 03:03 PM | #10 |
I hope I have it right, the temp unit I bought I was planning to place in the manifold where I plugged it up earlier. I was going to remove the plug and drop it in.
11-17-2020, 03:28 PM | #11 | |
You'll also need a coolant bypass. It goes from the water pump to the intake. You've got enough ports there that it shouldn't be a problem. I found a Gates hose #12044 that had just the right bend for the way I installed mine.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson Last edited by truckster; 11-17-2020 at 03:37 PM. |
11-17-2020, 06:20 PM | #12 |
The coolant bypass was something that came up before, I had it routed from the pump to the manifold but in order for the vintage air system to be installed I need that port off the top of the water pump. So I called Edlebrock and Vintage Air to help trouble shoot and the direction I was given by both is to not dedicate that top port of the water pump for a by pass.
Its covered in this thread I had on that issue. I sure hope I was given the right approach. http://67-72chevytrucks.com/vboard/s...d.php?t=813439 |
11-18-2020, 07:17 PM | #13 | |
I did a crankshaft sensor search for a 1997 Chevy C1500 with a 5.7 and found something like this to plug the hole. Would this work? Id need the M6-1x16 hex flange bolt though https://www.ebay.com/itm/OEM-Replace...sAAOSwbsdVKdWg This is the engine I have https://www.summitracing.com/parts/NAL-12681432 |
11-21-2020, 03:16 PM | #14 |
I think I got it right, the distributor went flush in as I rotated the engine and the 1st cyl rocker at the front had compressed and returned. At that point the timing line on the balancer met the tab. The distributor though was pointing straight to the front of the engine and not to the 1st cylinder.
11-21-2020, 03:17 PM | #15 |
When I rotated further the 2nd rocker compressed and returned and at that point the distributor was pointing right at the 1st cylinder but the mark on the balancer wasnt in line with the timing tab. All normal?
11-21-2020, 07:31 PM | #16 |
Moderator
Rotate the crank back to where the notch lines up with the marker on the timing cover....
Lift distributor up about 3", turn the rotor counterclockwise one tooth (about and inch) and reinstall the distributor.... If it doesnt go all the way down just rotate the engine until it goes al the way down. To double check its correct...rotate engine crank clockwise until pressure is felt in number one plug hole, line up notch and check position of rotor button... BTW...always rotate the crank clockwise...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
11-21-2020, 08:15 PM | #17 |
What I've also found when installing the dist is most of the time the oil pump drive needs to be turned back a bit counter clockwise. Last week when I put in a new dist, I setup the timing mark at TDC compression for cylinder 1 and then just kept putting in the dist and removing it and reinstalling it. It walks the rotor in a clockwise rotation each time it bottoms fully and finally got it pointing to where I wanted #1 plug wire. then just rotate the dist a little till the rotor tip is just before #1 plug. Snug the dist clamp and fire it up. this will put you real close
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
