![]() Join Date: Mar 2003
Suburban rwal
So I upgraded axles and brakes on my 91 Suburban to a full float 14 bolt rear and a Dana 60 front. The front axle got a conversion to 3/4 ton rotors. Still have the 1/2 calipers on it. Have a 3/4 ton master (not installed yet). Issue is a spongy pedal and I'm leaning towards the RWAL dump valve not working quite right. NO bleeder on the valve. I previously had issues on my other Suburban with the same issue. I am considering removing/bypassing the dump valve. Yes everything is adjusted correctly and have bled the system thoroughly. Any thoughts?
Re: Suburban rwal
Deleted.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-13-2023 at 06:37 PM. |
Re: Suburban rwal
My '91 Blazer had RWAL, I removed it when I swapped in 1 tons.
John '91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's |
Re: Suburban rwal
Was the difference noticeable?
Re: Suburban rwal
Made quite a difference in braking. Have a real brake pedal now. Couple of pics
Re: Suburban rwal
Left over parts
Re: Suburban rwal
May have to re-do a little bit. I think the stock combination valve is a weak link with the elimination of the dump valve. Pedal is way better, but not quite there
