10-26-2015, 04:22 PM | #1 |
Exhaust manifold question.
Some stock cast iron exhaust monifolds have a copper tube in the exhaust port, and some don't . Can someone tell me what this is for? I am talking about Chevy ramshorns from the 50's, 60's and maybe into the 70's. Thanks oleguy
10-26-2015, 04:29 PM | #2 |
Re: Exhaust manifold question.
Passenger side manifold? If so, it's for the choke warm-up as shown in this picture of my 58 Corvette.
10-26-2015, 05:39 PM | #3 |
Thanks for the quick answer, however this is not the tubes that I am asking about. There are four tubes in each manifold, one in each exhaust port. they look to be about 3/8" dia. Both rite and left side have them.
10-26-2015, 05:40 PM | #4 |
I don't think they are copper. They are for smog.
"Life is too short to drive a boring vehicle". Later, Wayne |
10-26-2015, 05:56 PM | #5 |
yup those are most likely from a 70 veh and are for emissions. most people remove them and put a screw in cap plug
1967custom |
10-26-2015, 08:23 PM | #6 |
Exhaust air pump? I had one on my old Toyota that injected air into the ports to lower emissions.
Truth is i have never heard of this kinda stuff on the earlyer years you mention but i could be wrong.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-28-2015, 05:40 PM | #7 |
Thanks for the info.
10-29-2015, 03:17 AM | #8 |
Cluster King
To be more specific it is for an "air" system which is short for air injection re circulation. It uses a belt driven pump on the front of the engine and plumbs piping into the exhaust manifolds. This forces fresh air into the exhaust to help reduce emissions.
It was more common on early vehicles (late 60's, early 70's) with California emissions. As time passed, most of these equipped vehicles had these systems removed and scrapped because of pump lock up. If you buy some aftermarket rams horn exhaust manifolds, they will be made to except the "air" tubes and come with plugs if the system is not being used. Hope this helps answer your question. Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
