Old 04-26-2001, 02:37 PM   #1
j mcgrat
Post Lowering
Hello,
I am looking a send my truck another 3 inches closer to the pavement (72 GMC 1/2 Ton). I want a level look, no rake. The spring set I am looking at is the 3" front and 3" rear sets from Eibach. Should I have different drops from front to rear? Will I run into troubles with this amount of drop? As far as rubber and rims go, I am going to have 15x10 alloys with 295/50R15s.
Thanks in advance.
j.
1972 GMC 1/2 Ton
Tilt/Powersteering
Powerbrakes/Front disc
Clearance lights
MORE TO FOLLOW WHEN THE TRUCK IS FINISHED
j mcgrat is offline   Reply With Quote
Old 04-26-2001, 06:17 PM   #2
BadAzz70PU
Long Lost Member
Post
To give your truck a level look you have to go down a lot more in the back than the front. My truck is down 6" in the back and only 3" up front and its still raked 1" although it doesnt look like that. Here is a pic of the 3/6 drop:
1970 C10 LWB
-Worked 350
-Dropped
-Tangier Orange Paint
Visit my Web Site: www.low70.com
College student at Clemson (SC)
Home in Langhorne Pa
Tony
1970 C10 LWB
-14.09 @ 96mph
Web Site
1995 Eclipse GSX
-15.46 @ 88mph (stock, not for long)
BadAzz70PU is offline   Reply With Quote
Old 05-03-2001, 08:30 PM   #3
67dragtruck
67dragtruck's Avatar
Thumbs up
That is one fine looking orange truck you have. Looks very nice
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 05-08-2001, 12:17 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Post
To level most trucks to have to drop the rear to inches more than the front. If you take a look at my web site, I went with 2.5 spidals and 4' shackel/hanger. The truck is as close to level as you can get and keep some usability in the truck. I have trouble with the bump stops because I have not cut them. I plan on doing it sometime but I will probably won't need to with the addition of some custom made traction bars.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-09-2001, 08:39 PM   #5
Chucky72
Post
the same size tires all the way around helps at level look to. are you running thoughs up front to. i was thinking that size tire before to
-~-1972 Custom/10
Deluxe Lwb-~-
350ci/th350 - 22 options
1972 Chevrolet C/10 LWB 350ci/350th
completely apart
Chucky72 is offline   Reply With Quote
