Old 07-03-2002, 04:27 AM   #1
hifiguy
68 4x4 suburban suspension/disc brake questions
I'm currently looking at buying a 68 4x4 suburban that has a 4 inch lift and has a 79 chevy front axle installed. I think the 67-68's normally had drum brakes in the front so I assume that the reason they swapped in a 79 front axle was to gain disc brakes. Now my question is this: while looking the truck over I noticed that the left side rear shackles were bent out about an inch or two. After looking more closely I noticed a crack in one of the shackles aroung the upper bolt hole. To me it looks as if the spring perches on the 79 front axle don't line up exactly where the OEM 68 leafs sit, and because whoever did the swap didn't take the time to relocate the drivers side spring perch, they had to bend the shackles out to accommodate the new spring location that is now determined by where the spring perches reside on a stock 79 front axle. Does this seem like a correct diagnosis of the problem, or am I way off base? Can a 79 front axle be swapped into a 68 with no problems? If not what should be done? Is it a common swap? Any info would be greatly appreciated as I'm new to the 4x4 versions of the 67-72's
hifiguy is offline   Reply With Quote
Old 07-03-2002, 05:40 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I was under the impression that the spring perch spacing was the same on all GM front axles. But if it's cracked you got problems. Those are not the easiest things to crack, sounds like it might have landed hard. Only the rear spring perch locations changed, as well as rear shock mounting points.
Welcome to the board.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-03-2002, 10:48 AM   #3
Pont
I need another Barley Pop
Pont's Avatar
I'm currently running a Dana 44 disc brake front axle out of an 80 Blazer in my 67 SWB 4x4. It bolted right up. No problems. Jims70GMC is correct on the rear leafs. The centering pin on the 69 and newer is offset where the 67-68 are centered from eye to eye. Shouldn't have any problems with a 79 front axle from what I know of this.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
