Old 03-21-2005, 12:35 PM   #1
frsyth72
Angry Need Starter help!
Well here is the story, a couple months ago my starter went out on my 72 blazer (350/350/205). Anyways I put a new (reman.) starter on and it ran good for about a month then it started grinding really bad then cought on fire, big cloud of smoke and that great burnt electriacl smell. I got a new starter and put it on again it ran good for about three weeks and started grinding. We noticed that the flywheel had gotten chewed up from the grinding and threw a new flywheel on with and warrentied out the starter again. it started grinding really bad fron the start. we started really playing this the clearances with this new starter (Before I only needed on shim for the alignment of the other starters) but with this new one we had to stack up 5 shims on the outboard bolt to get the clearance right but it would still grind when we went to start it now I have put in a couple Chevy starters before and have never had any problems like this and have had three other people look at it with me. Can someone please offer any advise on what I might be doing wrong or what the problem might be. Oh and we where using the gauge that came with the shims to check the clearances. Thank you in advance for any help you can give, I am lost.
'72 k5 Blazer
'76 chevy short bed 4x4
frsyth72 is offline   Reply With Quote
Old 03-21-2005, 12:39 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Sound's like a cheap started I was having this same problem when I bought my starter from auto zone I finally bought one from napa and have not had the problem since and that was 2 years ago..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-21-2005, 12:44 PM   #3
frsyth72
Well I did get the first two from auto zone and the others from Checker. I guess that I could check out a Napa one also.
'72 k5 Blazer
Old 03-21-2005, 12:47 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Did they give you the wrong starter? I tried getting a starter at Schucks but the guy could not find the right one. Every one that his computer said was right, looked nothing like the correct stater. I went to NAPA and they found the right one first try.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-21-2005, 12:51 PM   #5
frsyth72
I assumed that it was the right one since we got them from two different stores. Thanks for the idea, I guess it is two votes on going to Napa and checking theres out.
'72 k5 Blazer
Old 03-21-2005, 12:53 PM   #6
krue
Designated A-hole!
krue's Avatar
I wound up having to get a new nosecone for mine. Put the starter about 10/1000's closer to the flywheel.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-21-2005, 02:52 PM   #7
53burb
53burb's Avatar
I had a problem with my "new" starter for a while. It turned out to be the nosecone had a crack in it causing the same type of problems you had. Also, there are two different flywheels for SBCs, a 153-tooth and 168-tooth. The starter has to be the correct one for the flywheel you have.
53burb is offline   Reply With Quote
Old 04-11-2005, 10:43 AM   #8
frsyth72
block welding
Well I got to looking more at my starter this weekend (it took me a while to get back to it because I broke my elbow ) Anyways I noticed that the Block was cracked across the starter bolt hole and travels up about and inch on each side. Now my question is how can I fix this??? Is there a way to weld the block? what all do I need to get it done? Thanks in advance for any help or advice!
'72 k5 Blazer
