Old 04-15-2005, 06:11 PM   #1
Brad_Olson
Active Member
Brad_Olson's Avatar
1986 305 timing tab
My '86 305's timing tab is pretty dirty and all I can see are the "teeth"; the numbers are covered. I think I know what the teeth indicate but want to be sure so I know I'm setting the timing I think I'm setting.
Think of each tooth point as a high spot and the halfway point between 2 teeth as a low spot. There's one low spot that's wider and deeper than the others; I believe this is TDC. The first tooth counterclockwise from TDC is 2 BTDC, the next one is 6 BTDC, and so on. The low spots represent 4 BTDC, 8 BTDC, etc. Currently at idle the mark corresponds with the 2nd low spot, meaning the engine's initial timing is 8 BTDC.
Does this sound right? Thanks!
Brad
Brad_Olson is offline   Reply With Quote
Old 04-15-2005, 07:19 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I don't know how much this helps, but I believe the white mark was pointing at TDC when I took this pic.
http://www.slonaker.net/images/truck/TDC.jpg
I will be working on the truck tomorrow, and might be able to answer your question better then.
BTW, mine is an '86 with a 305 also.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-15-2005, 08:53 PM   #3
Brad_Olson
Active Member
Brad_Olson's Avatar
Thanks! According to the photo I'm correct about the location of TDC on the tab, so now all that remains is to verify that it's 4 degrees from tooth to tooth. If you could please check that tomorrow (as long as it's not an inconvenience) I'd really appreciate it.
Brad
Old 04-15-2005, 08:56 PM   #4
Prerunner1982
Prerunner1982's Avatar
i wish i had a timing tab.....
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-15-2005, 09:01 PM   #5
SS79chevy
join the club
1979 chevy c10 short bed step side
BBC in the works
SS79chevy is offline   Reply With Quote
Old 04-16-2005, 01:22 AM   #6
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Brad -
Here's what I got for a timing tab for a 305. Maybe Slonaker will be able to confirm this. Hope this helps.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-16-2005, 03:50 PM   #7
1986Silverado
What I drive
1986Silverado's Avatar
is that 12 at the end?
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 04-16-2005, 08:42 PM   #8
Brad_Olson
Active Member
Brad_Olson's Avatar
Yes, quite a bit - thanks! So it looks like the teeth are 4, 8, 12, etc. and not 2, 6, 10 like I thought, which means I set my initial timing to 10 BTDC and not 8 BTDC. I drove it around a little bit like that today and I didn't hear any detonation w/89 octane so I'll leave it be for awhile.
Brad
Old 04-16-2005, 08:58 PM   #9
1986Silverado
What I drive
That is why I asked if that was 12, I to thought that was 10 and it is past that. So my is probably around 14-15 initial!
2006 Chevy Equinox
Old 04-17-2005, 01:54 AM   #10
boxrodz
boxrodz's Avatar
You're welcome, Brad. (Sure is it tight where the tab is located.)
1986Silverado -
Yes, the last timing mark is a 12 (ie. 12 - 8 - 4 - 0 - 4).
boxRODz
