05-11-2006, 08:03 PM | #1 |
3/4 ton vs 1/2 ton 2wd
just curious what the biggest difference is between 3/4 ton and 1/2 ton
i assume bigger rear axle/8 lug anything else? found a 72 3/4 Burb for a good price and i have always wanted to build a bagged cruiser out of one *edit* i did a search and turned up nothing, sorry if this has been asked before Last edited by skanave; 05-11-2006 at 08:04 PM. |
05-11-2006, 08:28 PM | #2 |
Re: 3/4 ton vs 1/2 ton 2wd
You can change the front and rear to 1/2 ton pretty easy. Change the rear end and panhard bar. On the front change outer tie rods,upper ball joints and the whole lower a-frame(including ball joints)and spindle.
05-11-2006, 08:30 PM | #3 | |
