Old 04-22-2007, 07:21 PM   #1
lbpd719
Zappaphile!
lbpd719's Avatar
what it this, and should it be glowing?
ok,
after replying to "what did you get done" and not having done a thing, I went out to my truck to clean up some of the stuff in the cab. I fired it up and as I was moving around the AC boxes which the PO disconnected (I had the truck running just to trickle up the battery) I noticed a glowing coil in the AC box which is still connected to the firewall..
here is a pic.. Any ideas anyone? the larger coil in the rear is the one that was glowing pretty well (was glowing but didn't come out well in the picture). It went out when I turned the truck off..
Thanks in advance for any info..
719
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 04-22-2007, 07:25 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: what it this, and should it be glowing?
that is the blower resistor. If your blower was turned on anything but high, then yes, it should be glowing.
Old 04-22-2007, 07:45 PM   #3
lbpd719
Zappaphile!
lbpd719's Avatar
That makes sense.. Thanks for the info..
one day I hope to get all that stuff back together, but might want to paint the dash first, just cant decide..
Old 04-22-2007, 07:54 PM   #4
DangerBoy
Am I correct in assuming that if the resistor is bad then the blower wont blow?
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline   Reply With Quote
Old 04-22-2007, 09:42 PM   #5
cowdoc
Won't blow on anything but high, IIRC.
Jacob
'67 C20 fleet/wood; 250/SM420, coil rear...it's a work truck
cowdoc is offline   Reply With Quote
