Old 06-15-2007, 11:29 PM   #1
**grumpy**
**grumpy**'s Avatar
Help with bumper install
I feel like a dummy, but I'm having a hell of a time getting my bumpers on.
I'm using my old front bumper on the rear of my suburban, because I was told by several dealers they are the same, front and rear, for the burbs.
Mine is a 53 BTW
I didn't want to take the brackets off, but I cannot get the holes to line up at all.
It seems to "spring" when not installed. I tried to pry it, and no go.
Is there a trick? or do I have to take the brackets off no matter what?
**grumpy** is offline   Reply With Quote
Old 06-16-2007, 08:21 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Help with bumper install
How far off are they? Trying loosening the brackets. If you dont want to do that, line up one of the holes and put a bolt in it. Then use a really BIG pry bar to torque the brackets to line up the rest of the holes. You may need two people to do this.
Hart_Rod is offline   Reply With Quote
Old 06-16-2007, 09:15 PM   #3
solidaxel
solidaxel's Avatar
On one of my other trucks I had a hard time also, so I just put them on with some 3/8" Grade 8, put them on loose and line them up then tighten one at a time
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
