11-08-2007, 03:27 PM | #1 |
Correct name for a "3 on the tree"
What is the correct name for the three speed trannies that came in the 67-72 trucks. My truck is a 69 the originally had a straight 6.
does anyone know the size of the final drive gear? |
11-08-2007, 03:58 PM | #2 |
Re: Correct name for a "3 on the tree"
Three speed on the column is the correct name for it I believe.
I am curious of the rear gear ratio also. I have been told 3.73:1 and I have been told 4.11:1 but I don't have a tach in the truck so I can't figure it. My truck is a '72 2wd I6 w/column shift 3 speed Long fleet w/ no options other than leaves out back and the gauge package. Any ideas on the factory gear ratio? |
11-08-2007, 04:20 PM | #3 | |
Green club
My truck was born a 71 with the standard L6 and 3 on the column too, the stock rear end came with 3.73's in this truck. Someone will chime in I am sure with more accurate info. Also, call it what you want but I always refered to the 3 speed on the column as '3 on the tree' too. It probably is suppose to be standard on the column or something like that.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
11-08-2007, 04:26 PM | #4 |
I believe the stock 3spd manuals were Saginaw three speeds,but could be wrong...
11-08-2007, 04:45 PM | #5 |
What do you mean by final drive?
If you are wondering about 3rd (high) gear on the 3 speed. It is a 1:1 ratio.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
11-08-2007, 05:11 PM | #6 |
3.73 i believe were STANDARD on all manual transmission pickups, blazer, burbs. auto's should have been 3.08 or 3.54 depending on 1/2 3/4 1 ton. hope this helps
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
11-08-2007, 06:47 PM | #7 |
I have a radical idea!
Were 3.73's standard on V8 truck also?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
11-08-2007, 06:49 PM | #8 |
If they had manuals..all my 2wds with 350/TH350s had 3.07s or 3.08s unless they had been ordered otherwise.All my 4wds with 4spds had 3.73s on 1/2 tons...
11-08-2007, 06:53 PM | #9 |
Who's got steelies?
I guess 3 on the tree works. The owners manual says something like conventional H-pattern column shift.
Rear drive ratio seemed to vary with engine and transmission. This is what GM offered in 1970 1/2 tons: http://www.wkinsler.com/truck/index.htm#Power, other years may vary.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
11-09-2007, 06:42 AM | #10 |
Maybe i should have been alittle clearer. I meant to ask for the manufacturers name and part numbers associated with it.
i thought they were saginaws but i was not sure, i have never heard them called anything but 3 on the tree. thanks notherngmc that is what i was asking for. long stroy short i am trying to have a carb tuned to the truck and need to know, or at least act like i know, what i am talking about. thanks all. |
11-09-2007, 08:49 AM | #11 |
When you say 3spd that means 3 on the tree to me.I guess column shift 3spd or column shift manual.It`s becoming obvious why we the people dubbed the "3 on the tree" term.Seems to work best.
