05-05-2008, 05:07 AM | #1 |
Stock axle desirability?
Well, I just finished swapping a '02 Yukon axle under my truck, now I have a stock '70 12 bolt with 2" wheel spacers that I don't know what to do with. Anybody need one? I hate to scrap it, but I don't really want to hang on to it either.
Aaron |
05-05-2008, 05:59 AM | #2 |
Re: Stock axle desirability?
Do you know what ratio it is? Is it a posi?
05-05-2008, 06:42 AM | #3 |
Truck and auto performance nut
how easy was the Yukon axle swap and what all did you have to modify?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 05-05-2008 at 06:43 AM. |
05-05-2008, 02:06 PM | #4 |
Yes! We inquiring minds want to know!
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater. |
05-05-2008, 03:42 PM | #5 |
71stub,
It's not posi and I don't know what the ratio is yet. I need to pull the inspection cover and check... but I'm thinking 3:73. As far as the install of the Yukon rear, I'm going to start another thread about that. Aaron |
05-05-2008, 05:05 PM | #6 |
Born Psycho
i hope you beefed the yukon axle, if it's a 10 bolt it's a weak S.O.B. you might want to save your 12 bolt just in case. we build a lot of the 10 bolt truck axles at work, i just built one friday that lost the left side carrier bearing completely--the ging gear was barely touching the pinion. funny thing about it was the truck would move in reverse but in drive it was noisey enough to wake the dead.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-07-2008, 12:27 AM | #7 |
Well Jerry,
The newer 10 bolt has the same dia. axle(1.31) and spline(30) as a 12 bolt, so I'm not too concerned. Aaron |
