Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-19-2009, 10:34 AM   #1
Ont67shortbox
Check my combo,please
Could someone give me some TRQ/HP numbers and a estimated 1/4 mileET please,here is the combo.
427 .030 over
TRW forged pistons .250 dome
Chev *241* oval port/open chamber heads 113cc
approx 10.6 comp
bowl work,gasket match
2.25/1.88 stainless valves
Comp solid FT 282s cam 2400-6800 rpm
244/252@.050
.590/.598 lift
Edelbrock RPM Intake, gasket matched to heads with 1" spacer
Modified 750 dp Holley
2 inch Hooker super comps/3 inch exhaust
built 350 turbo trans
Neil Chance 9 1/2 3500 stall convertor
F*rd 9 inch 4.30 gear
31 x13x15 tire
67 short box pickup weight approx 3800lbs
lowered 4 1/2F 6 R trailing arms/coil springs
block is at machine shop being cleaned,now is the time for me to adjust my combo if you think its needed,Thanks for your help
Ont67shortbox is offline   Reply With Quote
Old 02-19-2009, 10:42 AM   #2
bigjimzlll
bigjimzlll's Avatar
Re: Check my combo,please
12.80 in da 1/4..just a wild azz guess though. I'm not familiar with that head casting or how much "work" has been done to them.
I think the gear,tire and cam are just about matched for the engines RPM band.
I would guess a real world 420 or so HP
Look at the old L88 427's with 12-1 CR a solid cam and dual quads made 430 HP.
Sounds like a fun combo.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-19-2009, 11:15 AM   #3
Wild83C10
Wild83C10's Avatar
Need more head info and what kind of intake? If the heads flow enough I think you should run better then 420hp and 12.40s.
Check out this thread and post your info in there. More head and intake info would help though.
http://67-72chevytrucks.com/vboard/s...d.php?t=317628
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-19-2009, 06:07 PM   #4
americanmusc1e
americanmusc1e's Avatar
My desktop Dyno Says about
562hp @5500 and 583ft-lb @ 4000
wasn't sure about the heads so i used Edelbrock performer heads for a baseline.
a much bigger set of heads like Victor CNC show about
605hp @ 6000 and 599 @ 4500
americanmusc1e is offline   Reply With Quote
Old 02-19-2009, 09:07 PM   #5
bigjimzlll
bigjimzlll's Avatar
If you noticed I said real world HP numbers. I have nothing against desk top dyno programs if you use them to track trends. It has been my experience...having built and dyno'd a few engines.... making over 1 HP per cubic inch is not as easy as magazines make it look. If it was the big 3 auto makers would of been doing it all along.
If you think about GM's 454 in the late 70' early 80's made barely over 240 HP.
My full race 540 males 840 HP...thats 1.55 hp per cubic inch
The 427 at 605 HP is 1.4x per cubic inch. Out of a pump gas truck engine?
Anderson,CA
Old 02-19-2009, 09:26 PM   #6
Wild83C10
Wild83C10's Avatar
The desktop dynos are a bit on a high side usually. The best thing to use them for is to compare parts. Will changing the cam give you the results you want? That is what the desktop dynos are good for.
I have one of the better desktop dynos and I have every single bit of info for my motor and I know the motor doesn't put out what it says it should.
If the 427 listed above put down 500hp that would be a very good number.
turbo=
Old 02-22-2009, 09:11 AM   #7
americanmusc1e
yeah i thought that was a little high myself but i just checked it for a baseline, somewhere i heard that Desktop dynos are about 20 percent off on HP and 10 percent off on tourque but i'm not sure
Old 02-22-2009, 05:09 PM   #8
1970chevy
can any body tell me what my 632 would make
block is dart
14to1 ross pistons
soild roller cam
316 /320 .50
830 lift
nos cam 4000 to 8100 rpm
dart pro 1 cnc 355cc
230in/188exh
420cfm
intake is a dart single thats port match with 1150 dominator
two stage nos 300 and 250 shot
ign is msd crank trigger with a msd programmable 6al-2 box
trans th400 with a brake
stall is coan 3500 now might put in a 5000 stall
dana 60 with 513 and a set of 410
tires are 33x18.5 15
truck is a 70 short bed step side thats 4link and back half
3600 lbs
thanks
1970chevy is offline   Reply With Quote
Old 02-22-2009, 06:48 PM   #9
bigjimzlll
bigjimzlll's Avatar
a lot
1000 on guts alone
Anderson,CA
Old 02-22-2009, 09:41 PM   #10
Wild83C10
Wild83C10's Avatar
I would hope that you had a plan and an idea of what kind of power you were shooting for before you spent that kind of money on a serious motor like that.
Sick combo though. I hope you have a cage. Good Luck
turbo=
Old 02-23-2009, 12:29 PM   #11
americanmusc1e
block is dart
14to1 ross pistons
soild roller cam
316 /320 .50
830 lift
230in/188exh
420cfm
3600 lbs
thanks
need more info on cam, what grind? what brand? at least LCA and Intake centerline so i can plug it into the desktop dyno
Old 02-23-2009, 01:57 PM   #12
Marv D
Registered Truck Offender
Marv D's Avatar
block is dart
14to1 ross pistons
soild roller cam
316 /320 .50
830 lift
230in/188exh
420cfm
3600 lbs
thanks
sniff, sniff,,, why does the work 'BAIT' keep coming to mind here
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 02-23-2009, 09:26 PM   #13
1970chevy
its a crane intake lift is .500 exhaust 4706 adv 324 at 360 dur opens at 47.0 btdc exh 123.0 closes 97.0 abdc and 57.0 atdc thats what i got of from the cam card if you need more info ill call daven port engines thats you built it
thanks
Old 02-23-2009, 09:28 PM   #14
1970chevy
grind num 324-362-19r
Old 02-24-2009, 09:42 AM   #15
americanmusc1e
thanks, i'll try to get to it sometime today
Old 02-24-2009, 04:50 PM   #16
Ont67shortbox
Maybe you should start a new thread to carry on with this combo, THANKS
Old 02-24-2009, 07:29 PM   #17
1970chevy
sorry
Old 02-24-2009, 11:28 PM   #18
americanmusc1e
having a hard time finding flow numbers on those heads, without that i can only guess
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
Old 02-24-2009, 11:41 PM   #19
1970chevy
whats your best guess i can call the enigne builder
thanks
