Old 06-21-2009, 08:21 PM   #1
Hawker7
Fitting for oil pressure line
I bought a new 350 crate motor and went I went to intall the oil pressure line that goes to my stock gauge but found out the connection in the new block is above the oil filter. On my old block the connection was on the top of the block behind the intake manifold and was a different size. Anyone what size fitting I need to run the line down near the filter? I went to NAPA and a few other places and they had no clue. Thanks
Hawker7 is offline   Reply With Quote
Old 06-21-2009, 08:38 PM   #2
dan42
dan42's Avatar
Re: Fitting for oil pressure line
Bummer. Nothing like something like that to stop your progress. You may have to make one up - get the fitting for the motor side and use the old fitting for the gauge side, and get a flair tool and put it together. Good luck.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 06-21-2009, 08:45 PM   #3
El Jay
Gone to greener pastures
I have to plead ignorance here.
Having never messed with a crate engine, are they metric?
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 06-21-2009, 08:48 PM   #4
Hawker7
I can run 1/2 tap in the hole so I believe it is standard. I'm sure GM changed over when they went to electric oil senders. I assume all crate motors are this way so I'm hoping someone else went through this when using their stock oil gauge on a crate motor?
Old 06-21-2009, 08:59 PM   #5
El Jay
With my GMC and now with my Chevy (Chevy does have an aftermarket gauge), the oil pressure pickup was/is 1/* NPT.
Had the same thing on a BBC boat engine and a BB F, F, F, 1 of them blue oval things engine.
Old 06-21-2009, 09:08 PM   #6
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
I didn't buy acrate motor, but I.m installing a 98 votec (fitting is above filter) and I went to o"reilly and bought a line kit for aftermarket guages. It had different fittings and the new line.
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 06-21-2009, 10:09 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you sure there isn't a plug in the hole up top behind the intake?
Old 06-21-2009, 11:40 PM   #8
El Jay
That was supposed to be 1/8" NPT
Old 06-22-2009, 12:01 AM   #9
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
Yeah thats where mine was!
mikajo39 is offline   Reply With Quote
Old 06-22-2009, 06:58 AM   #10
Hawker7
I checked and I don't think it is there. I checked my old block and see it, but not on the new one. Of course the block is in the truck so it makes it a little harder. Should there be one on the new crate motors? What does the hole by the oil filter do?
Old 06-22-2009, 06:59 AM   #11
Hawker7
It was on top by the intake on a new crate motor?
Old 06-22-2009, 07:25 AM   #12
Hawker7
From looking at some pics I took before I put the motor in, I think I see where it might be..You might be right, and there might be plug I overlooked...If that is the case, do I have to plug up the hole near the oil filter? I wish these motors can with some instructions. Would be nice to at least have a diagram of what needs to be pluged..I called summit a while back and all they told me was to put a plug in any hole that leaks when you first run it...
Old 06-22-2009, 07:36 AM   #13
hilandr452
hilandr452's Avatar
I just switched my 71 402 over from sender to gauge and the fitting was just above the oil filter. The fitting to the block was 3/8 I believe but the old sending unit was installed with a 1/8-3/8 reducer. Napa sold me a kit for installation that had all possible combinations for like 9 bucks. Oil gauge works perfectly from that location.
Dan
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 06-22-2009, 01:55 PM   #14
mikajo39
mikajo39's Avatar
Yeah it was, it was a late model block to like 90 and up or something like that. Do you know what year block you have? Also it was hiding from me i could barely find it when the engine was out of the truck
Old 06-22-2009, 02:25 PM   #15
Hawker7
OK, I think I found it. I think I dismissed it as my oil line fitting from my old block would not fit into the hole on the new block, so I thought that hole was for something else. Do I have to plug the hole I see that is on top of the oil filter if I use the hole on top of the motor?
Old 06-22-2009, 04:05 PM   #16
CPNE
Resident Curmudgeon
CPNE's Avatar
yes
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-22-2009, 06:09 PM   #17
mikajo39
mikajo39's Avatar
Yeah just go to a auto parts store and find a plug for it and put some thread sealer on it and pop it in. What engine did you get?
Old 06-24-2009, 07:34 AM   #18
Hawker7
I got the 260HP 350 crate motor. I ran the line to hole I found on top of the block and the gauge works now.
Old 06-24-2009, 07:36 AM   #19
Hawker7
Dan
Thanks, I did just that. I bought the kit from NAPA and it had all the fittings I needed.
