Transmission fluid question
Hey guys,
I have a 1997 C1500 with a 4.3 V6 and an automatic transmission. It has a transmission fluid leak, and I need to keep it topped off until I can get it serviced. Do you folks know the proper fluid to use? I have the manual that came with the truck, and it says to only use DEX III. However, the associate at AutoZone (and some other internet sources), claim I should be using DEX VI. Any and all help is greatly appreciated. Thanks in advance! |
Re: Transmission fluid question
Dex VI is backward compatible and can be used in place of Dex III. However, it's usually a lot more expensive, so Dex III is fine.
Mike |
Thanks bud!
Tags |
1997, 4.3, atf, dexron, transmission fluid |
