08-07-2009, 11:25 AM | #1 |
Help!!! ASAP Please
I have recently been laid off and need to get my truck back on the road. I just swaped out the old front suspension for a 79 front suspension. What I need to kow is, are there any spindles that will go on the new suspension that is 6 lug like what I had on it originally? that way I wont have to worry about new wheels and tires. Thanks a bunch guys.
08-07-2009, 11:57 AM | #2 |
Re: Help!!! ASAP Please
Woops, I ment are there any rotors that I can put on the newer suspension that is a 6 lug like I already have.
08-07-2009, 12:07 PM | #3 |
Rods
not for cheap... and not to replace cheap. if you do a seach here there a a few threads on it
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
08-07-2009, 04:23 PM | #4 |
They have them here for $75 each. http://www.truckandcarshop.com/trucks60_72/t60_115.html You will have to call to make sure they fit on late model spindles but I don't see why they won't
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
08-07-2009, 06:37 PM | #5 |
1961 crewcab
I posted a link to a threAD a few weeks back that a guy used 87+ 3/4 ton 6 lug rotors, check on the threads that I started, it should be close to the top.
08-07-2009, 06:38 PM | #6 |
67-72 parts collector,…
Yes. Many vendors sell them. Look at ECE. (Early Classic Enterprises)
They sell them for their 63-70 conversion kits,... but they will work on your spindles as long as the original rotors are the 1-1/4" thick version. Not the light duty 1" version.
08-08-2009, 12:05 AM | #7 |
60-66 Nut
Here is an alternative way of getting 6 lug disc brakes.
http://www.67-72chevytrucks.com/vboa...ad.php?t=35042 It would require some extra work, but if you're laid off you probably have some extra time. I guess it depends if you can acquire the needed parts on your budget. You might get lucky and find the parts in a wrecking yard.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-08-2009 at 12:06 AM. |
