12-02-2012, 08:57 PM | #1 |
Front top brackets
Hello Everyone, When I purchased my 71, the front corners of the top (pic below) was not attached with anything.
What does the brackets I need look like? Or where can I find a pair to buy. I have looked at several online and local vendors but was not abale to find any. Thanks for the help! Also I have read that ONLY single wall tops have lights on them....is that true??? I have a double wall with two lights on it so I was curious if this is common? Nick A.
68 C10 SWB W/ 72 FRONT CLIP 343SB TH400 64 C10 SWB 406SB TH400 74 SUBURBAN 454BB TH400 78 K10 SWB 350 TH350 6" ON 35" BFG MUD 71 K5 350 W/ TBI 700R4 6" ON 38" BFG MUD 00 K3500 DRW BIG BLOCK "DRINKING PRBLM" |
12-02-2012, 09:26 PM | #2 |
Active Member
Re: Front top brackets
The sun visor has a bolt that runs through it and attaches to the top.
12-02-2012, 09:32 PM | #3 |
NICE! I`ll have to check them out, I have two sets of sun visors.
Thanks for the help. Nick A.
12-03-2012, 09:06 AM | #4 |
This may help: http://67-72chevytrucks.com/vboard/s...d.php?t=369523 Post #4
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
12-04-2012, 01:15 PM | #5 |
Your lights look like they are in same place as my single wall !
12-04-2012, 02:30 PM | #6 |
12-04-2012, 04:34 PM | #7 |
The Blazer sun visor brackets are different from the truck brackets. They're a lot heavier to serve as a bracket for the top.
12-04-2012, 06:48 PM | #8 |
My double wall has the plug in (elec plug) like a single wall also??
If it is not factory, how would someone modify it without cutting into the top?? There is no evidence of cutting into the top???? Maybe I have a super duper special rare black top.....or maybe not!!!
12-04-2012, 11:01 PM | #9 |
I assume the top bolts onto the bed from the bottom like a normal double wall also?
12-05-2012, 08:56 PM | #10 |
Sure are, just put the top on last month.......
12-05-2012, 09:29 PM | #11 |
I have double wall on my 71 that i never put on but wish it had the lights my single wall rail is brittle purfect would be double with lights.
