Old 05-22-2002, 11:49 AM   #1
Jesse 67 c-10
Jesse 67 c-10's Avatar
Post Oil Pan question
Are there suposed to be any bafles in a stock sb oil pan? Asking because I heard something about this on the board recently and remember that my oil pan was completely bare inside when I pulled it to replace the gasket. nothing, just the stamped steel. My block came from a combine for the large journal steel crank and I used the stock oil pan. Is this ok on a street vehicle? I don't want to starve my engine for oil under hard braking, cornering or acceleration. Thanks
Jesse
Near Saskatoon, Saskatchewan, Canada. 67 c-10, Long fleet, Newly swapped front disks, 5 lug rear end, 327 v-8 with Vortech heads, edlbrock performer rpm air gap manifold, 1406 carb and comp XE 256 cam. Backed by a getrag 5 speed and 1 piece driveshaft. Finnally running, almost driving! www.geocities.com/chevy67jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
