11-08-2009, 02:55 AM | #1 |
Engine Troubleshooting
So I'm having some trouble with the truck. Whenever I put it in gear it idles down really low, stays running, but idles low. Then when I go to accelerate it shuts off. The only way I can keep it running is if I get it some gas before I put it in gear. My choke doesn't work so the clutch plate is always open, but I don't know if that has anything to do with it.
Any suggestions?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
11-08-2009, 03:29 AM | #2 |
Re: Engine Troubleshooting
There's alot of possibilities. Could be a bad vacum leak and a weak accelerator pump to go along with it. Sounds to me like the timing might be too slow and the idle screw set too high. What carb/distributor are you running and what type of choke does it have? Also, have you tried adjusting the idle jets?
Another thing to consider is the condition of the engine. Have you done a compression test on it? |
11-08-2009, 04:17 AM | #3 | |
I haven't messed with the idle jets or done a compression test. I don't know how to do either of those.
11-08-2009, 06:30 AM | #4 |
blood type; Retumbo
why is that vacuum port on the pass. rear of the carb open? that will do it. it should go to the PCV valve.
do I see a brake booster with no vacuum hose running to it? IIRC there should be another 3/8" port on the front of the carb. if so, run that to the brake booster. what's the number on the front of the choke horn? 80457S? the idle mix screws (idle jets) are on each side of the front metering block. ideal setting is 1 1/2 turns out from lightly seated. a good carb guy could do a full tune on it for you. Last edited by 68C15; 11-08-2009 at 06:33 AM. |
11-08-2009, 08:16 AM | #5 |
you might want to change the rubber fuel line to a metal fuel line before the fire
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 11-08-2009 at 08:40 AM. |
11-08-2009, 01:37 PM | #6 | |
