12-28-2020, 04:01 PM | #1 |
Lower control arm cross shaft compatibility
I'm in the process of rebuilding/upgrading the suspension on my '68 c20 right now and I have a question about the lower control arm cross shafts. I bought a complete subframe from a 73-87 squarebody to do a disc brake swap/5 lug conversion, but damaged the lower control arm cross shafts while trying to remove them for a bushing replacement.
The question - do the 67-72 cross shafts with metal bushings fit into the squarebody control arms that previously had rubber bushings? For some reason new 67-72 cross shafts are astronomically cheaper than the squarebody equivalent. If they don't fit, I'll have to hunt down another set of 1/2 ton lower control arms since new cross shafts for 73-87 are just as expensive as an entire control arm. Any help would appreciated!
1968 C20 -> C10 |
01-04-2021, 08:31 PM | #2 |
Re: Lower control arm cross shaft compatibility
TRW Automotive JRK1013 Suspension Control Arm Shaft Kit for Chevrolet C10: 1975-1986 and other applications Front Lower $70.35 on Amazon
Racerface Wellington, Ohio Freedom Isn't Free! GO BUCKEYES!!! Toys: 68 C-30 327-400turbo 68 C-30 Open Road Camper 327-400turbo 81 GMC Sierra 1500 250-350turbo Long Bed 83 K-10 4X4 Scottsdale |
01-05-2021, 11:23 AM | #3 | |
01-05-2021, 07:37 PM | #4 | |
After doing a little more digging I was able to find cross shaft assemblies on LMC for around $45 a piece instead of the $75+ I was seeing everywhere else. Another lesson learned, the ol BFH is not always the proper tool for the job. Especially when the replacement parts aren't as cheap as I thought haha
1968 C20 -> C10 |
