Old 10-29-2010, 05:46 AM   #1
67C10BUB
67C10BUB's Avatar
Any first start suggestions?
I am about ready to start my 5.3L for the first time and I was wondering if anyone had any suggestions, since the motor has been sitting for a while. I already filled the coolant through the upper hose and I poured a teaspoon of Marvel Mystery oil in each cylinder and turned the crank by hand (very smooth feeling). Do I need to bleed the air from the fuel rail, or will it works its way out? Any tips would be appreciated.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 10-29-2010, 12:00 PM   #2
mrhino
Re: Any first start suggestions?
Pressure the rail by turning the key on and off a couple of times, and make sure you have everything out of the way. and hit the key. good luck, let us know how it goes
mrhino is offline   Reply With Quote
Old 10-29-2010, 11:29 PM   #3
TR65
TR65's Avatar
67,
My 6.0 sat for 2+ years and would not start until I bled the air out of the fuel rail with the schrader valve on the rail.
It could be that the injectors were stuck and it was just a coincidence that it started when I bled the rail? I can't find anything about bleeding air out of the rail in the service manual.
There are a lot of threads about stuck injectors after the engine sits for some years.
Good luck,
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 10-29-2010, 11:35 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
since you can't use a drill to spin the oil pump like with a sbc...they say to pull power to the coils and then turn the engine over with the starter until the oil pressure comes up and/or you see oil flowing on the rockers. Then reconnect power and start it up.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-30-2010, 09:51 AM   #5
67C10BUB
67C10BUB's Avatar
Thanks for the info. I started it up last night and it ran great. Very loud with open headers, though. It did seem to have a few stuck injectors. For the first few seconds it sounded like it was missing a few cylinders and then it came alive. I was so excited to finally hear it run. Maybe I'll post a video on my build thread some time soon.
67 5.3L Build
Old 11-04-2010, 03:23 AM   #6
Ackattack
Ackattack's Avatar
Congrats, I know the feeling!
Ackattack is offline   Reply With Quote
Old 11-04-2010, 06:48 AM   #7
cdowns
cdowns's Avatar
on initial startups i always make sure that a freash fully charged fire extinguisher is close at hand
