10-19-2019, 08:41 PM | #1 |
Connector pins
I've looked at the thousands of pins out there and cannot find these or what their names are. I need 5 but will get more due to clumsy fingers. They look to be crimp on. The plug can be reused, but if I could order pin/plug combo that would be great. If any of you could steer me in the right direction it would be much appreciated. Thanks
10-19-2019, 08:58 PM | #2 |
Re: Connector pins
that particular connector shell does not look familiar to me.. amp, molex, metripak??
what application is it? based on the industry the connector belongs to, tried any vendors that carry the major components? just out of the blue, could browse a catalog like Mousers or Newark.. or email JK Electronics with a picture and they probably could ID the brand.. good luck!
I started out with nothing - and I still have most of it |
10-19-2019, 09:07 PM | #3 | |
Re: Connector pins
10-20-2019, 12:44 AM | #4 |
Re: Connector pins
If you have no luck finding it, you may be able to pry the crimp connections apart, remove the old wire, and lay a wire in there and solder it, so you re-use the pins.
