06-05-2022, 08:54 PM | #1 |
Moderator
How to adjust the idle vent valve (B carb)?
Yesterday, while trying to deal with my truck that was bogging/stalling, I had minimal tools, and in my panic mode, I put a few random turns on the idle vent valve. Then random the other way. I had previously rebuilt this carb, and the truck ran perfectly. I've now remembered/researched what this valve does, but can't find how to get it back into adjustment.
What's the correct procedure for setting the idle vent valve? |
06-07-2022, 01:17 PM | #2 |
Moderator
Re: How to adjust the idle vent valve (B carb)?
Nobody remembers how to adjust the idle vent?
06-07-2022, 02:07 PM | #3 |
Moderator
Some info here - http://67-72chevytrucks.com/vboard/s...d.php?t=679308
06-07-2022, 02:50 PM | #4 |
Is it a mono jet or model b?
06-07-2022, 07:09 PM | #5 | |
Moderator
B, manual choke. I must have known how to set it when I rebuilt it... but that was a few carbs ago. I'll check that link and BRB.
Ok, yes, I'd read that one already. No idle vent info in there. At this point, I will just go with "make sure it's open at idle and closed with any throttle application". But I'm open to suggestions/experience! Best info I can find: Quote:
06-07-2022, 08:27 PM | #6 |
Found this for you.
Down a bunch of pages (page 43)you’ll find the setting info and a bit further down you’’lol find the specs. https://www.carburetor-parts.com/ass...r-b-manual.pdf |
06-08-2022, 11:01 AM | #7 |
Moderator
