Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-06-2011, 07:01 AM   #1
Lippyp
English Chevy Owner
Lippyp's Avatar
Limp home mode
I am looking possibly at a 2000 blazer that has a few issues. It seems the truck is in limp home mode that restricts it to first and second gear. The only error code recorded is low voltage on the throttle position sensor which the guy is saying wouldn't cause that problem (are these expensive to replace?) . He's been told its likely to either be a fault on the MAF sensor circuit (is this common?) or a problem with the gearbox solenoid for third and fourth gear. Is this a common fault with the auto boxes? Could it just be a broken/loose wire or is it likely to mean a gearbox rebuild?
It would need to be pretty cheap for me to buy it with these issues, its done 112K miles
http://cgi.ebay.co.uk/ws/eBayISAPI.d...E:B:SS:GB:1123
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 01-06-2011, 01:38 PM   #2
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Re: Limp home mode
I didn't even know the older blazers like that even had a limp home mode? I'm guessing the third and fourth gear solenoids in the transmission are bad so it just can't shift into those gears not that its in limp home mode. I'm sure that throttle position sensor code could cause a lot of other problems as well.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-06-2011, 02:13 PM   #3
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Limp home mode
OK thats off the list then. How unusal is a 2001 4 door 4x4 LS with a 5 speed manual transmission? I thought all 4 doors came with an automatic tranny? Reason I ask is I've got a line on one that looks to be in good shape with a full dealer service history, 68K miles and an LPG (Liquified Petroleum Gas or basically Propane) conversion. (PG is half the price of petrol (gas) over here.
http://aberdeen.gumtree.com/aberdeen/30/68451530.html
Also what am I missing spec wise with an LS over an LT?
Phil
'67 C10 long fleet.
Old 01-06-2011, 04:03 PM   #4
matthew20061
69' Chevy Stepside
Re: Limp home mode
I'm no expert on blazers but i've never even seen a blazer with a 5 speed only seen the 5 speed in the s10 trucks. My brother has a 99 s10 with the 5 speed and its great. I would go with that over the automatic.
-Matthew
Old 01-07-2011, 12:00 AM   #5
chevyndn
Re: Limp home mode
matthew20061- ive got a 97 2 door blazer with a 5 speed, but like you said Lippyp ive never seen a 4 door with a 5 speed.
chevyndn is offline   Reply With Quote
Old 01-07-2011, 03:19 PM   #6
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Limp home mode
I've had a bit of an email session with the owner of the second truck. It seems that he's the third owner, the first is listed as Vauxhall/GM so it looks like it may have either been a press car or more probably a demonstrator so that could explain the unusual spec of it being a four door manual. The wheels are original but I have to say all of the research I've done I've not seen anything like it. It does have a couple of small issues that you guys might be able to help with, the drivers seat adjustment (manual I think as its an LS) doesn't adjust much and the drivers electric window switch is a bit tempermental so I'm guessing it might need a new switch and the seat could be anything from a floor mat in the way to something jammed in the track etc but nothing that major.
Phil
'67 C10 long fleet.
Old 01-20-2011, 12:49 PM   #7
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Limp home mode
Going to see the manual LS this weekend, 99% sure it'll be coming home with me as its a 1400 mile round trip to where its at! 2001 LS with a manual transmission, 3 owners the first one being GM, 66K miles, full service history, a huge file of receipts and bills, tow bar, in lovely condition, had both front hubs replaced two years ago, has a multipoint LPG (propane) conversion, so it will run on gas (petrol) or well, gas! It also has the optional Bose stereo system but cloth seats. I think the slightly odd spec may well be down to the fact that the first owner was GM so it may have been either a demonstrator or even a press car.
Heres a couple of pics.
Phil
'67 C10 long fleet.
Old 01-20-2011, 01:37 PM   #8
matthew20061
69' Chevy Stepside
Re: Limp home mode
Looks nice, that's pretty cool Gm was the first owner of it!
-Matthew
Old 01-20-2011, 03:56 PM   #9
geezer#99
geezer#99's Avatar
Re: Limp home mode
At least it's the right color. Make sure you get the spare tire with the cover and brackets. It fits inside in the back on the driver's side.
As far as rare I've seen 2 four doors in Vancouver with a manual. I bought an 87 with 4 doors and a 5 speed new so I know they make them.
Happy Hunting!!!!
Old 01-20-2011, 06:38 PM   #10
chevyndn
Re: Limp home mode
thats sweet, wish i could find a four door 5 speed!
Old 02-02-2011, 01:15 PM   #11
geezer#99
geezer#99's Avatar
Re: Limp home mode
Thanks for the inspiration Lippyp. Bought the wife a new DD. Not red but it's dark green. She calls it Kermit.
Old 08-02-2011, 11:01 PM   #12
PhilnTX
5-speed 4-door blazer
Sorry for bringing back an old topic, but do you have pictures of this Blazer?
My email is philntx@verizon.net
Phil
PhilnTX is offline   Reply With Quote
Old 08-03-2011, 04:09 AM   #13
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Limp home mode
Heres a few.
Phil
'67 C10 long fleet.
Old 08-03-2011, 09:43 AM   #14
PhilnTX
Re: Limp home mode
Thank you very much!
