Old 01-18-2020, 02:00 AM   #1
conoco
conoco's Avatar
Help with leak from speedo cable
I have a little leak coming from my speed cable that goes into my transfer case. I took out the old cable and replaced it with a new one and it is still leaking. Should I change out the bullet also? What am I missing? Any help would be great. Thank you
conoco is offline   Reply With Quote
Old 01-18-2020, 02:31 AM   #2
tj1970cst
Re: Help with leak from speedo cable
The bullet has a small seal that rides on the speedometer gear shaft. The seal can be bad and/or the gear have a groove worn. You replace the whole shootin match for less than $20.
tj1970cst is offline   Reply With Quote
Old 01-18-2020, 02:37 AM   #3
conoco
conoco's Avatar
Originally Posted by tj1970cst View Post
The bullet has a small seal that rises on the speedometer gear shaft. The seal can be bad and/or the gear have a groove worn. You replace the whole shootin match for less than $20.
Thank you! I will do that tomorrow. Hopefully the parts store has it. Alaska doesnt have a good track record for parts getting here lol. Thank you.
Old 01-18-2020, 02:52 AM   #4
tj1970cst
I bought mine off Ebay. It shipped out of Memphis. I do not know how that works to where you are. I think it's more of a transmission parts place thing than a auto parts store. I did the Ebay thing because the transmission suppliers near me are 30 minutes out of the way in bad parts of town. Worth $5 shipping to me.....
Old 01-18-2020, 05:06 AM   #5
Fbks_Cruiser
Fbks_Cruiser's Avatar
Check out this thread:
https://67-72chevytrucks.com/vboard/...d.php?t=639106
That adapter is getting hard to come by. Last posts in that thread indicate a possible source.
I went to Young’s Gear here in Fairbanks. They didn’t have any new ones but gave me 3-4 used ones and said “try em out. Keep what works best and bring the rest back. No charge.” Great guys, super helpful. That was 3 years ago. Fixed my leak.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 01-18-2020, 11:20 AM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Help with leak from speedo cable
I don't think you will find it at a parts store. Only on line are a good transmission shop.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-19-2020, 04:24 AM   #7
tj1970cst
Oops, didn't look close. I was thinking yours was a 2wd with a th350.
