03-08-2012, 05:38 PM | #1 |
Recalculating.....
Body mounts
Ok my Blazer is completly together. I was checking out my body mounts and they are pretty dry rotted. I going to buy the complete kit with new bolts and change them. Since My truck is not all apart is this going to be difficult to do? Im figuring Id loosen the back part and use a 4x4 and jack and change them. Im pulling the motor out next week so the radiator and firewall shouldnt be too bad Right? Any tips, suggestions or problems I may have?
Brian - (BBrendal) 1969 Chevy Camaro Z28 1972 Chevy Blazer CST 2004 GMC Yukon (The truck that pulls the car trailer) 1972 Chevy Blazer CST #2 (Finished and sold!) Blazer build link... http://s1213.photobucket.com/albums/...rendal/Blazer/ |
03-08-2012, 07:26 PM | #2 |
Re: Body mounts
Brian,
I did mine before it went out for body/paint. The carriage bolts are tack welded to the tub at the factory so you have to carefully grind or cut the tack weld without damaging the floor and paint. A little tricky. The full kit I bought through LMC fit well but I found that the spacer sleeves were not as stout as the originals. I couldn't reuse the original carriage bolts (and leave them in without going through the pain of grinding the tack off) because they were pretty rusted inside the sleeves. With your rig already being done, I would jack the body as little as possible while installing the new mounts - much easier if you only have to jack it up very slightly to pull the rubbers and spacers out when the bolt is removed. I used a floor jack and a piece of 4X4 to jack the tub as needed, but I had removed all mount nuts. Definitely good to have a helper feeding the new bolt down from the top and holding it down keeping it from spinning while you tighten it. Good luck. Keep us posted.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
03-08-2012, 08:06 PM | #3 |
Re: Body mounts
You're body lines/gaps might need tweaking afterwards. Make sure the top is on.
03-11-2012, 12:42 PM | #4 |
Re: Body mounts
You might want to consider poly mounts. I did the rubber kit and within a year mine started to look just as bad as the 40 yr old rubber I replaced them with.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
03-12-2012, 10:47 AM | #5 |
Re: Body mounts
I have had Energy Susp brand black poly mounts on my rig sence 1993 and they are still holding and doing thier job!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
