Old 02-10-2012, 10:27 AM   #1
lowrodderchev
lowrodderchev's Avatar
dash gauges
Hi everybody my current dash has the big Speedo and gas gauge and small clock oil water voltage gauge but i want to switch to a dash with a tach in it can i do this or will it require a different dash plug in thanx
lowrodderchev is offline   Reply With Quote
Old 02-10-2012, 03:48 PM   #2
TheApocalyptican
TheApocalyptican's Avatar
Re: dash gauges
Depends on the year of your truck, and I believe the year of the gauges in relation to your truck. I can tell you that if you have a electric speedo, then customizing the gauge cluster is the only way to add the tach. With the electric speedo, there is no simple plug and play solution.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 02-10-2012, 03:56 PM   #3
lowrodderchev
Re: dash gauges
its on a 75 blazer k5. its a cable driven speedo and the dash im looking at is out of a 75 to. i thought about swapping all the gauges out to custom ones but im trying to stay ona abudget.
Old 02-10-2012, 09:17 PM   #4
ghettoluxury
ghettoluxury's Avatar
Re: dash gauges
direct swap then.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-10-2012, 10:12 PM   #5
lowrodderchev
Re: dash gauges
oh cool i was worried because my current dash has the clock on the left bottom and the clock has its own seperate plug
Old 02-10-2012, 10:29 PM   #6
ghettoluxury
Re: dash gauges
Yeah the tach does also.
Old 02-10-2012, 10:36 PM   #7
lowrodderchev
Re: dash gauges
so on the new dash the fuel gauge is going to be there it will still work ok?
Old 02-11-2012, 12:41 AM   #8
misternash2
Re: dash gauges
Follow the printed circuit on the original dash back to the connector. Then follow from that same pin on the connector and see if it leads to fuel guage on the tach dash. If not, write down what each pin does on the original (the connector is numbered-look close) and move them to where they need to be in the tach dash.
misternash2 is offline   Reply With Quote
