Old 02-29-2012, 02:17 AM   #1
crazy longhorn
Fabricate till you "puke"
3.42-3.73 gear swap?
I have an 02 silverado(2wd), that is running a 3.42 gear. My parts truck is sportin a 3.73 diff, & I know it will "bust" the mileage a tad going 3.73, but be nice behind that 4.8, pullin a stock car trailer My ? is how much tune do I need to play, to make it work properly? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-29-2012, 01:29 PM   #2
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
Re: 3.42-3.73 gear swap?
Just put them in and go, no need to wory about tuning the motor
'85 swb
droppedgmc is offline   Reply With Quote
Old 02-29-2012, 04:31 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Only thing the PCM would need to be programed for is to correct the speedo.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-29-2012, 04:34 PM   #4
crazy longhorn
Thanks guys crazyL
Old 03-05-2012, 08:03 PM   #5
1BadAction
1BadAction's Avatar
You can do without, but it should really be tuned to fix the shift points also. They will be different.
2010 Basalt Black Porsche Cayenne GTS - Daily driver
1991 2500 Suburban, Black - 454/80E tow monster, soon to go under the knife... Again.
1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac
1BadAction is offline   Reply With Quote
Old 03-05-2012, 10:24 PM   #6
crazy longhorn
I had wondered about the shift points.....the old school stuff , always messed with the shift points ,running lower gears. Tiss my 1st rodeo on the 3rd gen , I love my 02 silverado(4.8), & that is what the diff swap is about. I have a 5.3 to roll in my old 69 longhorn/backed with a Richmond 6 spd box, & 3.42 gears. She will be goin "rock stock", with a little tune.....maybe add the cam upgrade& valve springs, next season. The old 383 has showed me all she has.....but fuel mileage was not in the picture. crazyL
Old 03-06-2012, 01:25 AM   #7
clinebarger
Its the same theory as changing speedo gears & calibrating a governor in a older ride, Just its all in the "Flash Memory" in the PCM.
3.42:1 to 3.73:1 isnt a huge change. It would run fine....But better with a good tune.
clinebarger is offline   Reply With Quote
Old 03-06-2012, 01:37 AM   #8
crazy longhorn
Any betts on mileage difference? My thoughts are probably about nothing in town....but I may need to slow down a tick on the hyway?
Old 03-06-2012, 01:46 AM   #9
clinebarger
Tire size?
Old 03-06-2012, 02:25 AM   #10
crazy longhorn
235/75/16....they are a little shorter than what was on the 4wd parts truck. crazyL
Old 03-06-2012, 11:21 AM   #11
1BadAction
1BadAction's Avatar
Nothing significant, and on heavier 4.8 trucks (4wd, extended or crew cab), it's easy to get worse mpg with the 3.42s than you do with 3.73s.
For the size tires that are generally considered truck tires these days, 3.73s are the way to go.
Old 03-06-2012, 04:19 PM   #12
biggsteve97
we did a 3.73-4.10 swap in a 2000 Siliverado 5.3L 1/2 ton 2wd years ago without any reprogramming and the speedo was only about 1-2 mph off. no real effect on shift points either. It ran great. so we just left it alone after the install.
biggsteve97 is offline   Reply With Quote
Old 03-06-2012, 09:04 PM   #13
crazy longhorn
Thanks again, to all for the info....it sounds like I will bolt in & play. I may go with the tune later, but this one is my DD. Hotrods 1st! I am working on the 5.3 into my old 69.....dam, this old man has refound some sore muscles, tearing the parts truck down if it jacks with me too hard, I just lite the "smoke wrench" tho...thanks again,crazyL
Old 03-06-2012, 11:40 PM   #14
Rgilbert
Hi, I have a 2008 4.3 2wd reg cab with 3.23's but I'm planning on going from the stock 245 to 285 tires so I want to get 3.73 or 4.10 gears but which one? And what are the pros and cons? I wouldn't mind the better acceleration either!
Rgilbert is offline   Reply With Quote
