03-02-2012, 01:19 AM | #1 |
1969 Blazer...To be my daily driver
I have been reading many of the VERY informative threads here for a couple months now before finally picking up my new addition last Saturday, a 1969 Blazer. I flew to Phoenix, transferred title and drove here home about 400 miles. Lost about a quart of oil from the valve covers, well just took it out of the engine and spread it across the under carriage, tail gate and hatch. I did the compression test today to find she is pretty tired, varible compression through out with two cylinders pretty low. I squirted a little oil in the cylinder to see if it helped bring up the compression, it didn't so I may just try a valve job on the heads first.
Any way here is how I got her... 4" Lift (block rear) and 33" BFG Mud Terrains 350/350 Np205 with 12 bolt and 3:73 gears The rear seat is out of my brothers Jimmy (beonkey), this one came with a descent condition original CST bench he is testing to see if he wants it. |
03-02-2012, 01:28 AM | #2 |
Re: 1969 Blazer...To be my daily driver
My brother found the matching rear superlift 4" leaf spring pack on craigslist so I can ditch the block. I got the existing interior cleared out and new valve covers installed.
Rancho 9000XL on stand by along with 2008 Escalade seats (2nd and 3rd row) Family Cage Exhaust Carpet and interior, etc etc |
03-02-2012, 01:54 AM | #3 |
Nice! A very clean truck. I think it has the perfect amount of lift.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
03-02-2012, 02:05 AM | #4 |
VA72C10
very nice! looks solid
Looking for a 67-72 swb or blazer project in or around VA. |
03-02-2012, 08:32 AM | #5 |
Welcome Dustin, it looks like you have a very solid start to your Blazer! There are a lot of guys on here that are very helpful and you can find a lot of great ideas.
Make sure you save your original bucket seats and brackets when you install your newer seats. They are very desirable to a lot of people on here if you want to sell them. I decided to start a thread on my seat install if you want to check out what I did. I didn't want to clutter your build thread up with my stuff. http://67-72chevytrucks.com/vboard/s...61#post5224761 David Last edited by 29od1; 03-02-2012 at 08:59 AM. |
03-02-2012, 09:41 AM | #6 |
GEARHEAD
Between you, your brother and dad, that's quite a collection of blazers.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
03-02-2012, 10:31 AM | #7 | |
03-02-2012, 10:34 AM | #8 |
03-02-2012, 10:54 AM | #9 |
Yeah Bro, finally on here! Looking good. Scrub the tub and cruise it over for some Al's liner. Looking good.
Posted via Mobile Device |
03-03-2012, 10:51 PM | #10 |
very nice find looks very sharp
03-03-2012, 11:31 PM | #11 |
So yesterday I installed poly body bushings. Today I removed the rear 4" block and stock springs. I replaced them with them with the matching rear 4" Superlift springs (used in great shape) to match the front, I also installed 4 Rancho 9000XL shocks. Before installing I measured it out and realized the rear would be lower and it is. I kinda like that look anyway, kinda stock but taller... This may level out a little as I believe the front springs are much newer than the rear, but I am OK with it either way.
Now tomorrow I need to finish with the valve covers, plugs, wires etc so I can test the new suspension parts. Today was a long day between trips to the parts store for u bolts and laying on the concrete fighting the nuts and bolts. Before AFTER: |
03-04-2012, 12:53 AM | #12 |
GEARHEAD
If you check around you will find that the rear sag is common on these 1st gen blazers. I think they might have been that way from the factory. Most people will buy a lift kit with 2" more lift for the rear than the front. I have all original springs and will use a combination of air shocks and a short lift block to level it out.
03-04-2012, 08:23 AM | #13 | |
I think you are right about them coming from the factory that way, that is how my Dad's has always been. Maybe not as much drop as mine has now to to the age difference in the springs. For the time being I will leave it alone, if it turns out I don't like it this way I will probably drop the front 2". |
03-07-2012, 10:31 AM | #14 |
Well after some thought I decided on a crate motor from summit (GM Performance) 350/290 HP. So I pulled everything but the block out, block comes out today. I am going to clean up/replace some of the wiring the PO's did as well as some of their other handy work (i.e. Great Stuff window and door foam), there is red, black and white paint in the engine compartment, etc etc. I need to be quick as I need this on the road asap and the new engine arrives today or tomorrow I hope. Anyway, here are some before and during pictures. I will check the block today, I think it may be original, if it is I will keep it and take my time building up something fun for the Blazer down the road.
03-07-2012, 10:41 AM | #15 |
The Al's Liner arrived yesterday so I need to start prepping for that also...
03-07-2012, 02:09 PM | #16 | |
New Member
If you haven't ordered the motor yet, Jeg's was offering free shipping on all GM performance parts crate motors. Shipping is usually about $150. |
03-07-2012, 05:58 PM | #17 |
Thanks! Summit shipped it for free also to my door. Thanks for the heads up.
03-08-2012, 12:25 AM | #18 |
Sweet! Someone who has the same lift as me. How does yours ride? Mine needs a lot of work before I can get it on the road and the PO used '73+ springs on the front, so I've been trying to decide whether to just get the proper 4" Superlift springs for the front, or sell the current lift as a '73+ kit and get something different.
Beautiful truck.
1954 Ford F-100 1956 Chevy big window 1970 4x4 Blazer CST 1987 Land Cruiser 1990 Chevy K3500 454 |
03-08-2012, 01:32 AM | #19 |
Love it! Congrats. Would love to live down there again so I could take weekend trips to Johnson Valley.
Jeff |
03-08-2012, 11:05 AM | #20 | |
03-08-2012, 11:08 AM | #21 |
03-08-2012, 11:44 AM | #22 |
03-08-2012, 11:59 AM | #23 |
03-08-2012, 12:18 PM | #24 |
Yesterday I got the original clutch hole in the fire wall filled and a few hole PO's made. Engine compartment gets attacked today and tomorrow. The way the wires are run is really bothering me, but that will have to be taken care of on a weekend once she is up and running... priorities. Started prep for the Al's liner as well. The crate motor gets delivered tomorrow... hopefully I will have it in this weekend.
Some friends helping me out... Last edited by DustinU; 03-08-2012 at 12:19 PM. Reason: grammer |
03-08-2012, 07:29 PM | #25 | |
Does the back of your Blazer sag any? Mine doesn't, but it's pretty much stripped down, too, so I can't tell how badly these springs sag. I think I'll ultimately stick with the 4" springs, but another option I'm looking at is going to 2" in the front.
