Old 11-07-2012, 10:07 AM   #1
felm0001
felm0001's Avatar
250 HEI Timing, vacuum advance question
Long time reader first time poster,
I don't know too much about timing and ignition, but I used shifty's thread and installed this HEI from summitracing in my 1967 c10 with the stock 4.1l L6 and the old rochester 1bbl.
the truck starts and idles at 550rpm nice and strong.
Under load I and getting pop, bang, rocks and coffee can style ignition + black smoke. I set the vac can wide open at 9deg, then closed it a quarter turn at the time (that took an hour or two). There is definitely a spot there where ignition gets a bit smoother under load (probably around 7-7.5 deg adv out of the can), but still no joy.
I might have the initial timing at 4deg advance, unless each hash is 2deg and the 4 on the harmonic balancer is really an A... then I would be at 8deg initial advance. I set the timing by ear, then put a light to it.
according to summit the specs for this distributor are:
16 degrees of mechanical advance
and an adjustable 5-9 degrees of vacuum advance
so without the vacuum advance I think I am at(16 + 4 or 16 + 8) 20deg or 24deg total advance
with in the last 1-2 months: plugs are new, wires are new, valves are new, pressure check was around 150 on all cyls.
I feel like this is a timing issue, but if the vacuum advance is only adding advance, and it runs fine without the vacuum advance plugged in (I took her around the block), shouldn't the measly 5-9 deg advance only help underload? is there another issue I am overlooking that could cause this poor ignition?
felm0001 is offline   Reply With Quote
Old 11-07-2012, 10:38 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 250 HEI Timing, vacuum advance question
WELCOME!!!
Did you disconnect the vac advance when you timed it?It needs to be disconnected and plugged.
Did you check for full 12 volts at the dist.Even though you followed "shifty"'s very good instructions,you may have corrosion reducing voltage.
Did you use dielectric grease and tighten the firewall plug well?
My manual shows TDC at idle on a manual trans and * BTDC with an auto.
These are just the first things I thought of off the top of my head.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-07-2012, 01:03 PM   #3
felm0001
felm0001's Avatar
Thank you for the reply,
Yea, I disconnected and plugged the vac advance when I timed.
Yep, I rewired the whole engine harness with 12 gauge. I am currently still picking the tar crap out of the bulkhead connector. (I have a duck tape bulkhead connector in there now)
The firewall plug is tight. I did not use any dielectric grease though. The battery is new as of Jan this year and the posts look clean enough, could the issue be from the draw on the distributor if it fires fine with the vac advance disconnected?
I have the Haynes GMC truck manual and he has 4deg advanced for the 1967 250 manual on points. Not saying he is right, but that is what I have been going off of.
When I set the timing initially I turn the distributor until she ran smooth, then I set it to the closest mark on the balancer, which was i guess is 8deg of advanced.
But I am down for anything so, I will see if I can get it running smooth at TDC at idle and then see if that sets the vac up for a bit more success.
Old 11-07-2012, 01:47 PM   #4
geezer#99
geezer#99's Avatar
Try 12-14 degrees advance. My 250 ran like that.
Old 11-07-2012, 02:37 PM   #5
69gmc292
Did you check to see if TDC on the balance is true TDC? I have seen balances spin and that will throw your timing off. Also is your engine stock or has it been rebuilt? In my 292 I run about 8-10 degrees of static timing. I also put an HEI curve kit in it and I am running the lightest springs so my mechanical advance comes in faster.
69gmc292 is offline   Reply With Quote
Old 11-07-2012, 06:22 PM   #6
felm0001
felm0001's Avatar
geezer#99, ill give it a try.
69gmc292, yea the balance should be set, I used the napkin in1cyl spark plug hole method. Lined up at 0 just fine.
As far add the engine goes I'm not too sure, I had the head off and put in new valves, push rods, and rocker arms 2 months ago. Compression in the cylinders were consistanly 150 and the tranny and clutch worked so i stopped there for now.
I am going to unbolt the distributor tomorrow and play with it a bit based on your alls' recommendations. Would it be better to be as retarded as possible at idle to make room for the vac advance?
Old 11-07-2012, 06:48 PM   #7
geezer#99
geezer#99's Avatar
Won't hurt it. I ran mine with 14 initial plus 10 from the vacuum at idle.
Old 11-08-2012, 12:40 PM   #8
felm0001
felm0001's Avatar
Ok here is the results from today,
I tried 0 initial advance and that didn't work out. My theory is that more advance is needed to solve the misfire issue.
I went up to 12-14 and it ran smooth, but when it throttled up there was black smoke and unfired fuel out the pipe. I reduced the vac advance and it only made it worse. I found that more initial advance fixed the misfire on the throttle up. (please correct me if I am wrong, those are observations not mechanical facts)
So now I have teased the initial timing set way advanced off the balance scale, but there is no misfire and she runs strong at 500 rpm. I have the vac can wide open @ 9deg advance.
**She throttles up fine, but now on the way down there is misfire and black smoke out the pipe. I tired more initial advance and everything got worse, I tried less initial advance and same result. I tired backing off the vac advance and it was worse. Teased the fuel mixture screw on the carb and no joy.
any ideas?
Old 11-08-2012, 12:51 PM   #9
geezer#99
geezer#99's Avatar
Time to look at the carb. Likely flooding!!
Get it idling then look in the carb and look for excess fuel.
Old 11-08-2012, 12:58 PM   #10
felm0001
felm0001's Avatar
going out to try that now.
Old 11-08-2012, 04:09 PM   #11
felm0001
felm0001's Avatar
carb was a bit wet... so I fiddled a bit with the mixture and found that the pop and bang was happening once I was up trying to maintain high rpm, throttling up was fine, but at high rpm I think it is getting too much advance. I tried adjusting the distributor while at 1000-1500 rpm to see if I could get it running smoothly and I could, but once I brought it back down I had retarded the initial timing pretty far. something might have high fived the valve cover... ran fine after I set the timing back to 8deg adv so I am going to ignore that for now...
And everything still runs smooth with the vacuum can disconnected.
I am connecting the vac advance up to the carb where the old points distributor vac advance was connected. Maybe there is something up with my vacuum source?
Old 11-08-2012, 04:32 PM   #12
geezer#99
geezer#99's Avatar
THe vacuum source on the carb is manifold vacuum.
Better fix the wet carb problem. A rebuild might be in order.
Old 11-08-2012, 06:45 PM   #13
felm0001
felm0001's Avatar
I just rebuilt the carb in may. I have another rebuild kit so I can do it again, but I am going to see if it still floods without the vacuum advance connected tomorrow.
Old 11-08-2012, 09:16 PM   #14
70STOVEBOLT
70STOVEBOLT's Avatar
From everything I've read, inline sixes don't like a lot of initial advance. That is an A on the timing tab not a 4, stands for "Advance". If you connect a timing light and watch as you turn the distributor counter clockwise you will see the mark move toward the A. I don't know the range of my vac advance, but it is the stock distributor with a Pertronix Ignitor.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 11-10-2012, 06:43 PM   #15
felm0001
felm0001's Avatar
Thank you all for the responses.
70stevebolt: yea I kept my old distributor, I may upgrade it with the pertronix and plug it back in. Depending on how well this upgrade runs.
geezer: I have the stock intake and exhaust manifold in there right now, I am thinking of upgrading and getting a quad intake and just buy a new carb. Keep this one for my kids to play with.
So I took the truck down to a "classic restoration shop" we have around here. I have been there once before and wasn't too pleased, but the main man is wiser than me, so I figured he could help.
For 25 bucks he told me that the newer HEIs have too much mech advance built in so the vac is probably too much. He set the initial to about 14-15deg and capped my vac line. I took her home and she ran ok, had some popping and putting while idling at the intersection, so I set my timing around 8deg initial advance and am keeping the vac line plugged for now. Runs strong and I took her on the hwy at about 70mph for about 10 minutes. I have the cheapest 85 +10% ethanol gas in there so I assume 14deg + some higher octane stuff would run better.
Anyway, I guess the answer is, 16deg mech + 5-9 vac advance is too much advance for my 250.
250, distributor, hei, timing
