Old 12-07-2012, 08:56 PM   #1
bohmankid
bohmankid's Avatar
What did you do for fuel?
My motor is a 2001 5.3-liter LM7.
Hopefully someone can help me out and save me a few hours from Google
I guess I have the returned style fuel system with the regulator built in the lines on the manifold.
1) Does anyone have a parts list for their swap?
2) I suppose I will need a fuel pump (I want to use an in tank pump) and high pressure lines. Does anybody have part numbers?
3) What fitting did you use and where did you use them?
bohmankid is offline   Reply With Quote
Old 12-08-2012, 10:32 PM   #2
bohmankid
bohmankid's Avatar
Re: What did you do for fuel?
Bump
Old 12-09-2012, 09:58 AM   #3
Clyde65
Clyde65's Avatar
I would pm a guy named Clinebarger, he has an 85 suburban with the 5.3/4l60. I think they use the 87 truck tanks and pumps but he can set you straight.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-09-2012, 10:33 AM   #4
68fixeruper
68fixeruper's Avatar
Not sure on your pickup but i ran all 6an fuel hose. Its.more money but i wanted it to be a one time ordeal. You could use tubing and save some money you can order 20 feet or however long you need from jegs or summit. Just make sure u flare the tubing 37 degrees if running 6an fittings to it.
68fixeruper is offline   Reply With Quote
Old 12-09-2012, 01:59 PM   #5
Clyde65
Clyde65's Avatar
I also used the -6an stuff from summit! Works great!
Clyde65
Rebuild of Clyde
support our troops!
Old 12-17-2012, 10:20 AM   #6
smoky02
Location: Sunny, Florida, some might call it South Alabama
Do you remember what exactly you ordered Clyde and fixer? I went on summit and saw a kit with 20 foot of hose, but will that be enough?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 12-17-2012, 10:55 AM   #7
Clyde65
Clyde65's Avatar
I have the tank from Boyd Welding, it is in the rear, 20ft will just bearly be enough, but it is. I used a Pierburg external pump which is more & but a very good pump. ( http://www.turnkeyenginesupply.com/f...e-1-to-450-hp/). you can go less expensive for sure, a Walbro 255 pump along with the proper pre and post pump filter can get the job done.
Clyde65
Rebuild of Clyde
support our troops!
Old 12-17-2012, 11:48 AM   #8
smoky02
I actually just purchased the walboro 255 and I also have a tank from Boyd's Welding in the rear of my truck...so I guess I'll look into picking up 20' of steel braided hose.
Old 12-18-2012, 09:59 PM   #9
Mr. 250r
Mr. 250r's Avatar
I used my stock suburban tank and bought a walbro 255 which for me it was like.... 2 wires i had to hook up then.... regular SS hose from summit but make sure NOT to get the PTFE unless your using PTFE specific hardware and a corvette regulator
Here is my parts #s although they may be slightly different since im using a returnless setup and also used my old hard lines
Fuel rail fitting - rus-640850
SS braided hose - sum-230610
Hose end - sum-220690
Regulator fitting rus-640940
BR3W CITY helped me with my fuel line stuff
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 12-20-2012, 09:29 PM   #10
bohmankid
bohmankid's Avatar
Okay, I have most of the fuel system figured then. I have a few more questions.
1) The return line is not pressurized, is it? Do I need to buy the high pressure lines for the return line or can just use hose clamps?
2) Can I use my stock 87 sending unit? If so, how do you hook up the lines to the unit?
Old 12-21-2012, 02:29 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
fuel injection rated hose and fi rated hose clamps will be fine. There is pressure on the return line, but it is usually not enough to cause in issue. Despite this, do NOT use regular fuel line and hose clamps, at least spend the few extra $$ for fi stuff.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-21-2012, 03:14 AM   #12
Mr. 250r
Mr. 250r's Avatar
What you could do.... this is what i did at least and some other people im pretty sure but i kept the hard lines basically from the old fuel filter back and i used one of the compression union pieces from summit to convert the hardline to the SS hose if i had a lot of time and money i would probably do it all in hardline except a short piece going up to the fuel rails
2003 1500 Silverado
Old 12-21-2012, 11:58 AM   #13
bohmankid
bohmankid's Avatar
I was thinkin about using my hard line as well. Would anybody have part numbers for those pieces? I think they're like 15 bucks a pop aren't they?
Old 12-21-2012, 01:41 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Here are some of the ones jegs has, just find your AN size and hardline size.
http://www.jegs.com/p/Earls/Earls-Ha...49418/10002/-1
Old 01-01-2013, 04:46 AM   #15
502ms
502ms's Avatar
Just know that the fuel system on the LS is 58PSI, a whole lot more than our carbed systems are, so don't take any risks. I am going -8AN and -6AN on mine.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 01-03-2013, 08:37 PM   #16
bohmankid
bohmankid's Avatar
hey Br3w, or anybody, are there an fittings I can attach to my 87 fuel sender and screw onto the SUM-220690 that summit racing sells?
Old 01-04-2013, 01:48 PM   #17
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
iirc the 87 sender still has the TBI style connections, just regular "push on" hose nipples for rubber line and clamp. I keep finding square body guys saying to use the 87-91 blazer sending unit, but with those nipples I don't know what they are doing for feed line.
I have 3 trains of thought on this, none of which are tested, so theres my disclaimer.
1. slip extra FI line over the nipple, and use 2 fuel injection clamps. Doesnt' sound the best but they DO hold very well, even at 60+psi, do at your own risk.
2. You could clip off the nipple and try to use the "hard line" AN fittings on the "stub" from the fuel pump. If the pipe OD is right, this might actually work just fine...never done it..do at your own risk.
3. Have someone braze or tig AN fittings or Pipe fittings to the sending unit, then adapt from there. The most work, most cost, and most professional. Still at your own risk.
Old 01-04-2013, 05:31 PM   #18
bohmankid
bohmankid's Avatar
If all else fails I was thinking of option number 2. I just wanted to ask before I pull the trigger. This is my very first swap EVER, which I am doing all by myself, and it's a lot to take in LOL
Old 01-04-2013, 08:01 PM   #19
Jon01
Jon01's Avatar
I've done #1 on a couple swaps and not had any issues.
Jon01 is offline   Reply With Quote
Old 01-04-2013, 10:02 PM   #20
Mr. 250r
Mr. 250r's Avatar
Although a lot of people are against the double clamping idea but i know a 1st gen camaro that has that because when he did the swap in the early 2000s before ls swaps had any kind of aftermarket that was about the only option and its been fine since then so i would say its okay to use but if your paranoid i wouldn't suggest it lol
2003 1500 Silverado
c10, fuel, lm7, parts, system
