Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-29-2012, 08:26 AM   #1
Rannos
Rannos's Avatar
Finally Got it Back Together.
Been over a year sence the last motor gave up the ghost, but I finally have my ole rat rod running again. Hope to have all the lil kinks worked out by the time the track opens after the new year. Anyway here is a bad video I took while adding antifreeze the other night. Truck is running the same exhaust as the old motor, 3" with 2 chamber flowmasters that dump after the cab. Will need to run the exhaust farther back before I try driving it around town.
Rannos is offline   Reply With Quote
Old 12-29-2012, 03:14 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Finally Got it Back Together.
Cool , sounds good
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-30-2012, 12:55 AM   #3
shortbed70
shortbed70's Avatar
What's some specs on the motor?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-30-2012, 10:16 AM   #4
Rannos
Rannos's Avatar
It's a 383 with 10.3 to 1 compression RHS pro action 220 heads with Cometic gaskets Probe SRS pistons with Steelfire rings Scat crank and rods. It has a small street solid roller in it by Comp cams. It's built to take up to a 300 shot but I wont be spraying it for awhile. I am currently installing front disc brakes and a 2.5"/4" drop then it's off to Houston Drivetrain for a new drive shaft. Hope to have everything done in the next few weeks but my luck with this truck hasn't been all that great.
Old 12-30-2012, 07:15 PM   #5
Rannos
Rannos's Avatar
Making some progress today. Got the new rear springs and shocks in and the drop spindles and brakes in. Just need to mount the new master cylinder and prop. valve and run the new brake lines. Hope to get that done sometime this week.
Old 12-30-2012, 09:22 PM   #6
bigguy69
dazed and confused
bigguy69's Avatar
Sounds great!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 12-31-2012, 11:25 AM   #7
Rannos
Rannos's Avatar
Got it bac k on the ground.
Old 01-09-2013, 01:16 AM   #8
Tezjoe84
Tezjoe84's Avatar
Looks and sounds good brother... cant wait to see it when I make it down there!
Joe
1957 Chevy 3100 Stepside
Tezjoe84 is offline   Reply With Quote
Old 01-09-2013, 01:58 AM   #9
bk2life
Originally Posted by Rannos View Post
Been over a year but I finally have my ole rat rod running again.
i see a truck, where is said rat rod?
bk2life is offline   Reply With Quote
