07-07-2013, 08:21 PM | #1 |
1967-71 Door Panel Skins
Has anyone ever put new repro door panel skins on plain steel 67-71 door panels?
How do they attach to the door panels? Is it a real pain or something that is pretty doable?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
07-10-2013, 03:56 PM | #2 |
Re: 1967-71 Door Panel Skins
Anyone ever dealt with this?
07-10-2013, 05:00 PM | #3 |
Are you asking about outer door panel skins ? (the outside of the door) If so, then yes I have....plan on replacing the door bottoms at the same time. Patch panels are available.
07-10-2013, 05:10 PM | #4 |
I'm going to reskin my passenger door.
My plan is to use panel adhesive so to get the body lines aligned correctly. I'm still researching the best method to fold and crimp the edges. edit:
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe Last edited by Bigdav160; 07-10-2013 at 05:22 PM. |
07-10-2013, 06:08 PM | #5 |
Its very easy in my opinion to apply the interior door panel vinyl skins to the steel door panels. Thoroughly clean the original door panels and wipe down with acetone or similar product. You use a spray on vinyl adhesive on both and then lay the skin on the steel door panel aligning the holes for regulator and door relay while smoothing it out ( I use a small paint roller to roll over the door skin applying pressure), there is enough material to comfortably fold it over the edge wrapping onto the back ( Be sure to apply adhesive around the back edges of the door panel skin where its folded over onto the back ).
Paul @ GMCPauls |
07-10-2013, 06:30 PM | #6 |
, ignore my post.
door panel skins, not door skins
07-10-2013, 06:46 PM | #7 |
ouble post :please delete:
07-10-2013, 09:47 PM | #8 |
Yes I'm talking about the vinyl pieces on the inner door panels sorry for the confusion.
The door panels in my '71 are just the plain painted panels and I'd like to upgrade them. But I do have a set of olive green deluxe panels from a '70. Would it be easier to just paint the green ones? Is there a paint that will stick well to the vinyl? Posted via Mobile Device
07-11-2013, 06:59 AM | #9 |
They do make a vinyl paint but I've never had good luck with color lasting. You might speak with a local upholstery shop on what they may charge to change the color on the green version you have.
Paul @ GMCPauls |
07-11-2013, 08:26 AM | #10 |
One of the First
I have used finishmaster automotive interior paint with great sucess. It is pricey but very durable. Find a Finishmaster near you and they should be able to help you out.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
07-11-2013, 11:29 AM | #11 |
Cool Truck
I reskinned my door panels back in the spring and it went pretty good. I had the edges bunched up a little bit so they were a little tough going back in the door.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
07-16-2013, 12:11 AM | #12 |
Think I might try this on my green panels and see how it works since this paint is pretty easy to get.
https://www.rustoleum.com/CBGProduct.asp?pid=370
07-16-2013, 09:10 AM | #13 |
While were on the subject, anyome have experance with repo skins, quality etc.....
1967 C10 SWB Owner - Rustbelt Restorations |
07-16-2013, 09:37 AM | #14 | |
Cool Truck
I bought my repro skins about a year ago but just put them in back in March or April. I got the black ones from Brothers I believe and they are really nice quality if you ask me. They were easy to install but there were about 4 legs on each one I had to cut off to get the edges to sit flush. I am really happy with the product and it looks much better than driving without door panels. Posted via Mobile Device
11-22-2017, 01:54 PM | #15 |
So the skins can just be glued to the metal door panel piece?i see pre-assembled for 180, and just the skins for 110... i have the metal door panel, just no upholstery
