04-15-2013, 02:42 PM | #1 |
Glue-ing vs Stock Rubber for Windshield
We've had a lot of rain this past week. I know my truck has a leak in the windshield somewhere. I think I found it this past weekend. It appears to be leaking around the rubber seal around the windshield. I'm sure when I pop the shield I'll find rust and such. AFAIK, it's stock. Looks like someone in the past tried some silicone to seal a leak.
So, my Q is, when I go to replace the glass, is it advisable to use the more modern process of glueing the shield in place or use the stock style rubber? This is a rat-rod-ish truck so I'm looking for function vs. OEM look. This truck will spend more time outside than in a garage (due to space) so it has to withstand water.
James "Bierkan" Vierkant 1950 3100 on a 1972 C10 Chassis Truck Blog Motorcycle Blog |
04-15-2013, 07:43 PM | #2 |
Re: Glue-ing vs Stock Rubber for Windshield
Denee ended up installing hers with the "Modern" sealing method with the gasket acting as trim. She got the truck without a window and found it had some fitment issues that would not allow the window to seat in the gasket. Check out her thread.
04-15-2013, 07:46 PM | #3 |
Rat rod or not you don't want it to leak and not to rot. I'd strongly advise Steele Rubber Products ONLY - I've never read a bad comment about them. And install it like it came from the factory.
04-16-2013, 02:12 PM | #4 |
Anyone have pictures of the more modern flush mounted style glass?
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup 1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels |
04-16-2013, 02:16 PM | #5 |
I just put my 2 piece windshield in this weekend. I used the rubber gasket and will be going around it with urethane in the coming weeks. I was debating on doing the modern, but I wanted the rubber in there also. I am not too worried about the leakage.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
