Old 06-24-2003, 01:04 PM   #1
LonDog
1996-2000 Vortec Engine Swap (Help)
I was wondering if anyone knew of any sites that covered a 4.9 L or 5.3 L Vortec engine swap into a 1972 C10. I will either be getting a motor and tranny from a Caprice (cop car) or a truck. I'm sure others have done this but before I get started I want to see what I'm in for. I have looked for a while now and just can't find much. I would appriciate any responses. Thank-you.
LonDog is offline   Reply With Quote
Old 06-24-2003, 02:05 PM   #2
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
4.8L or 5.3L are only in the trucks, and from model years 1999 and up!!
Jason
Cap'n Hook is offline   Reply With Quote
Old 06-24-2003, 02:25 PM   #3
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
Jason
Old 06-24-2003, 04:17 PM   #4
LonDog
Sorry, either the 5.7 from a 1991 - 1996 Caprice or 5.3 from a new truck. Thank-you Jason. I should have been more specific.
Old 06-24-2003, 04:22 PM   #5
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
That's neat! If you use the cop car engine are you going to put the "Interceptor" badge on the back?
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 06-24-2003, 04:25 PM   #6
LonDog
Id probably get pulled over for that. But its a thought.
Old 06-25-2003, 12:08 AM   #7
Mike C
Mike C's Avatar
The cheapest/easiest swap would be a 96-98 in trucks Vortec 5.7 or up until 2000 in vans, it is basicall a first gen small block. If you want to go to a 5.3/6.0 street & performance sells motormounts for some applications.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-25-2003, 03:52 AM   #8
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Do those 96-98 truck Vortecs have a mechanical fuel pump boss or is it electric pump only? I am assuming it doesnt have the boss so you are going to have to run an electric pump and all that jazz with it...Right?
thanks
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 06-25-2003, 11:08 AM   #9
LonDog
It uses a high pressure fuel pump as far as I know. It is in the gas tank so I would run an inline.
I was definitally thinking about getting a 5.7 out of a van but I have a lead on a 2000 truck that is totalled. Thank you for the replies.
Old 06-25-2003, 12:31 PM   #10
Blue68
Blue68's Avatar
Here's a pick of my '97 truck engine. I converted to carb and while there is a boss for the pump, it isn't usable, it's blocked off. Stock, they use a high pressure in-tank pump. I'm running an electric pump myself for the carb. The wiring harness and pcm (you need a '96 pcm) made the cost to convert too high for the return. Maybe some day I'll go fuel injected, but it will be some aftermarket or TPI. You know looks and all the benefits. I' run the exact serpentine setup that came on the truck. Don't have the a/c plumbed yet though. The fan shroud is a BB shroud for our model with the '97 stock fan blade. Fit is perfect.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 06-25-2003, 05:22 PM   #11
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Late model serpentine belt systems are cool! My 78’ K10 with a crate 454 HO is set up like a L29 BB 454 from a 2000 model year old style 2500 series truck. Will be adding sequential fuel injection later this summer once I score a GM marine controller.
DirtyLarry is offline   Reply With Quote
