06-30-2013, 10:38 AM | #1 |
427 bbc
i am putting a 427 bbc in my 65 chevy lwb pickup. i would like to know how much trouble i'am gonna get into. what kind of frame mounts should i use put them in front holes on the frame or rear. what type of headers.will i have firewall clearance.what about fan clearance.can use electric fan.any thing else i'am missing.i'am sure a few of you guys have run into some of these problems.any help would be greatly appreciated.
07-01-2013, 08:59 AM | #2 |
Re: 427 bbc
I would post this in the engine section, they can give you a lot of detail, but my first take would be to find a mid eightys pickup with a big block get the dimensions and the engine perches and motor mounts from that donor truck but come to think of it that would be a 454 not a 427, better go the engine sections and see what they have to say. Kieth
07-01-2013, 10:13 PM | #3 |
Re: 427 bbc
I have a 396 in my '65 GMC project. Not sure on the mounts. I'd have to look. Plenty of firewall clearance. I have Hooker Comps for a 70-72 big block C-10. Top of frame rail is trimmed some for clearance but it may have not been needed. It also had Super Comps on it. I have a dual electric fan/shroud setup from Derale mounted on an aluminum radiator. Its about all I could find that would fit. Not much clearance even with a short water pump. Hopefully it cools well enough. I moves serious air.
I am thinking that maybe the motor could be moved back towards the firewall a little with different mounts for more clearance up front. Then it would start getting tight with HEI and valve covers. I am sure someone else knows more. |
07-02-2013, 12:14 AM | #4 |
Re: 427 bbc
07-02-2013, 01:13 AM | #5 |
60-66 Nut
Re: 427 bbc
Here are just a few threads with info on installing a big block.
http://www.67-72chevytrucks.com/vboa...ight=big+block http://www.67-72chevytrucks.com/vboa...ight=big+block http://www.67-72chevytrucks.com/vboa...ight=big+block http://www.67-72chevytrucks.com/vboa...ight=big+block http://www.67-72chevytrucks.com/vboa...ight=big+block http://www.67-72chevytrucks.com/vboa...ight=big+block
07-02-2013, 01:36 AM | #6 |
Re: 427 bbc
