07-23-2013, 09:21 PM | #1 |
amsoil z-rod oil feedback
Hi guys.
Need some feedback on this oil. Just changed to it and well just wanted to know if i did right. thanks. |
07-23-2013, 09:38 PM | #2 |
Re: amsoil z-rod oil feedback
I have 0 experience with that particular oil BUT Amsoil is top of the line. I would trust anything they make to do what it says it will do. I doubt you could possibly go wrong with any bottle with the Amsoil name on it. If I were you I wouldn't worry. Amsoil isn't some fly by night snake oil company.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
07-24-2013, 02:52 PM | #3 |
BUT, they're such a big company, that if you needed oil for a snake, they'd probably have it!
A buddy of mine was just telling me he's running it in his Dog with a 440. He DOESN'T run anything that's not top of the line.
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 Last edited by gofastnut; 07-24-2013 at 02:53 PM. Reason: Add'l info |
07-24-2013, 09:58 PM | #4 |
Fabricate till you "puke"
I have also heard good things about Amsoil....however, I still run the "rotten dinosaur juice" in my toys...(old school)? Any rate, 25/50 Castrol goes in the 383. 10/30 penz or shell rotella , goes in the Silverado. The Harley takes 20/50, & the Kendall GT, seems to work as well as the high priced Harley brand....the Wix filters work good on the sporty as well as the high priced K&N ? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-25-2013, 09:56 AM | #5 |
top of the line is Mobile 1
Racing 0W50 Regular Price:$98.00 quart |
07-25-2013, 11:41 AM | #6 |
It's Better With Nitro
It is a premium quality oil and has done quite well with several of my customers' hot rods...one of them does used oil analysis. I'll see if I can get a copy of one of his reports, but he's very happy with the zddp levels and TBN life.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
07-25-2013, 11:46 AM | #7 |
thanks guys for the info.
07-26-2013, 12:37 AM | #8 |
I run the 20-50 in my '63 (with a 396 flat tappet engine) with their filter too. I really like it. Seems that it runs just a hair smoother ( which is probably my imagination). I used to only run Kendall and Wix filters until now. Im slowly changing everything over to Am soil and so far so good. See if you can get the membership for 20$. I think in the long run, it ends up saving money if you do enough cars.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
